Electrical problem
Electrical problem
First, the basics.
2009 F150, SCREW, 52k miles, bone stock
This afternoon on the way home from work I was listening to the satelite, and my wife called me on the sync. All appeared to be working fine.
I went to run an errand, and noticed the clock was not on the display. It only said "F-150 Built Ford Tough". Now, my Radio/Satelite radio/sync are not functioning at all. I checked the fuses inside, all sync and radio related fuses are fine. I didn't see anything in the under hood fuse box relating to the radio.
All the radio buttons do not work, including those on the steering wheel. The a/c controls below work fine (thankfully).
Any hints or suggestions where I can look for problems?
Thanks in advance!
Thanks in advance!
I've had a weird issue like this with my more basic Sync module in my 2010 F-150. It was something to due with an issue in regards to my old iPhone. In order to truly reset the system, I needed to pull the fuse and actually wait a while, as the sync system still pulls power even when the truck is off (though it's just a tiny bit of power). Try giving that a shot, I don't recall which fuse off the top of my head.
