1963 Econoline Gas Tank Installation - Ford Truck Enthusiasts Forums
Old 06-04-2013, 06:50 PM
ChopperJon ChopperJon is offline
ChopperJon is starting off with a positive reputation.
Hey I'm just wondering where the overflow tube on the top of this tank is supposed to be run. I'm probably just going to run it over the tank and let it hang out the back as I assume it doesn't really matter. Any input would be great, first post I'm new here! Thanks for the help! I'll try and get some pictures of said econoline later.
Old 06-05-2013, 07:36 AM
OGB OGB is offline
OGB is starting off with a positive reputation.
It runs to the left side of truck through a hole in frame forward of the gusset that goes from the body side to the frame, then through a hole in that gusset and the up into the top of the box that encloses the gas filler hose. It has a metal return bend at he end of the hose (works fine without it unless you are fording some very deep water). Welcome I have a 63 econoline pickup. If you are having any trouble with the gas gauge make sure you run a ground wire from the gas tank to the frame.
Old 06-05-2013, 11:34 AM
kjhales kjhales is offline
kjhales is starting off with a positive reputation.
To add to OGB's reply, the vent tube runs to an inverted U that's about 12"-18" high, to keep fuel from leaking out. A straight horizontal tube over the edge of the tank could spill gas. The shop manual advises to avoid dips in any horizontal section to prevent fuel from puddling there, and horizontal section should drain back to the tank.
I had an engine fire once from leaked fuel, I try to cross the t's and dot the i's on fuel system work.
Old 12-04-2013, 10:58 PM
scoobyvanjack scoobyvanjack is offline
scoobyvanjack is starting off with a positive reputation.
vent line
sorry if i'm late sounding in, just reading around and this caught my eye. but kj's got it right run line to the stand pipe, "fluid separator" my out let from the stand pipe required a second section of hose that ran rear ward to back to a second hole in the frame just end keep it tidy. it just tucked into it but mine has the long body. later models have a box by the filler pipe some later still ran to a canister. even with a good ground wire my gauge is still a bit wacky. i may need a constant voltage regulator. one of the other threads tells how to build one if need be though are you a 6 volt system you may not have one if so. Dennis Carpenter sells the sender units if need be.
66 Econoline Fuel Tank surfmon Ranchero & 1961 - 1967 Econoline 10 08-21-2015 04:28 PM
1986 ford econoline fuel pump wiring help dennison.7 1968-2013 Full Size Vans 3 05-03-2015 10:09 PM
Looking for a gas tank for a 65 econoline jdavey Ranchero & 1961 - 1967 Econoline 3 05-10-2009 10:15 PM
67 Econoline M/C part #? E100PU Ranchero & 1961 - 1967 Econoline 10 10-15-2008 06:36 AM
Econoline glass seals Ole' Green Ranchero & 1961 - 1967 Econoline 12 08-22-2007 03:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
