First project! '61 uni - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
Old 06-04-2013, 10:25 AM
61steven's Avatar
61steven 61steven is offline
61steven is starting off with a positive reputation.
Talking First project! '61 uni
Hello guys! I am now the proud new owner of a 1961 unibody shortbed. It's a straight six with four in the floor, not the big window cab. I picked the truck up for $700 with a clean local title(when I find it). The rust on the truck body is pretty extensive, but the frame is solid. The seat and headliner are shot but the dash is all good and all there. There is a crack in the windshield that I didn't notice till i got it home. There seems to be a repair done on the crack already. The engine might be toast. When I picked it up the valve cover was off and has a bent push rod. I will be posting pictures here pretty soon. Donations of parts and knoledge are always welcome!
Old 06-04-2013, 11:16 PM
Bill W's Avatar
Bill W Bill W is offline
Bill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputationBill W has a superb reputation
Sounds like a great project! can't wait to see some pics of it.... I just had a front windshield put in mine (Again!) cost was about 180.
Also, Welcome to FTE!
Old 06-06-2013, 10:19 AM
61steven's Avatar
Im still trying to figure out a way to get pictures from my BlackBerry on to here(I recently destroyed my android phone).
Anyway, I have started to get into the truck and have broke the first bolt! It turns out that the rear end is locked up for one reason or another. I think it's the brake shoes being rusted in place due to the parking brake had been set for so long.
On the brake drum is there any retainer to remove before pulling it off? Im getting the expected resistance from it, but there is some give and spring to it!
Did these trucks come with a 9in rear end?
Old 06-06-2013, 10:24 AM
61steven's Avatar
So I have more information on the truck! Could anyone tell me what the glove box tag really means?
Serial number: G10jg17523
W.B: 114
Color: B
Model: 6100
Date trans: A
Axle: 11
Max. Gvw lbs: 5000
Crt net HP: 114
RPM: 3600
DSO: blank?
Old 06-06-2013, 01:10 PM
61steven's Avatar
I talked to a body shop earlier this afternoon and found out that one of the guys is selling a 4.6l running engine/tranny/wiring harness for $650 with 100k on it. Are brackets made for this conversion, or would i have to fabricate and weld something onto the frame? Also, what would that mean as far as the shift on the column since its an auto tranny?
Old 06-07-2013, 10:30 PM
61steven's Avatar
Old 06-07-2013, 10:32 PM
61steven's Avatar
Old 06-07-2013, 11:11 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
VIN: F10JG171523 / W.B. 114 / COLOR: B / MODEL: 6 F100 / TRANS: A Wrong code for 4 speed, should be an F / AXLE: 11 / MAX. GVW LBS: 5000 / CERT NET HP: 114 / RPM: 3600 / DSO: blank?
Welcome to FTE
1961/62: No DSO code unless the truck is a Domestic Special Order.
F10 = F100 2WD
J = 223 1V I-6.
G = Chicago IL Assembly Plant.
171523 = 1961, assembled May 1961.
114" Wheelbase.
B = Caribbean Turquoise.
F100 2WD, 5,000 lbs. GVWR
A = Ford 3 speed manual transmission, non syncro 1st gear (F = Borg Warner T-98 4 speed).
11 = Ford 9" Rear Axle / 3.70-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
114 net HP @ 3,600 RPM
Old 06-08-2013, 07:44 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Moved to proper forum. Your welcome Bill.......................lol
Old 06-08-2013, 01:18 PM
61steven's Avatar
my apologizes on the serial number, i was copying it down from a picture. I went out and wrote it down by hand so this one should be correct
F10JG171523
The last owner informed me when i picked up the truck that the tranny was not stock. He changed the 3 speed out for the current 4 speed in it.
Thank you for the information.
If the rear end happens to be rusted shut, and not just frozen brake drums, what are my options? is it possible to rebuild the axle or should i just look for another?
Old 06-08-2013, 01:48 PM
Correct VIN edited into post 8.
Old 06-08-2013, 02:45 PM
garbz2's Avatar
garbz2 garbz2 is offline
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
Moved to where it will wither and die on the vine.....
Garbz
Old 06-09-2013, 10:18 AM
37 Ford guy's Avatar
37 Ford guy 37 Ford guy is offline
37 Ford guy has a good reputation on FTE.37 Ford guy has a good reputation on FTE.
Quote:
Like Garbz said, you've done this guy no favors by moving his thread to the unibody section.....
Old 06-09-2013, 12:29 PM
61steven's Avatar
^I would have thought that a 1961 unibody would have been just find along with the 1961-1966 trucks. More traffic at least.
Old 06-09-2013, 12:49 PM
I agree, 61steven! Did moving the thread also make your pics disappear?
There's really nothing unique enough about the unis to justify segregating them to their own forum. Even the uni owners don't frequent this section much. I would request to transfer back to the 61-66 or least post any of your issues that aren't specific to the uni in the 61-66 section. Otherwise, you'll go for days or even weeks without any response! jmho
Randy
Does anyone know what the front ubolt size is for 61 f100? No1rascal 1961 - 1966 F-100 & Larger F-Series Trucks 3 11-09-2015 05:19 PM
Anyone ever use colorbond lvp, or something like it? 46Whizzer 1973 - 1979 F-100 & Larger F-Series Trucks 3 07-22-2015 02:21 PM
E350 5.4 to 7.3 Swap Thread DaviMac424 1968-2013 Full Size Vans 25 04-23-2015 10:11 PM
Feels like a new truck! Casey429 1987 - 1996 F150 & Larger F-Series Trucks 18 12-17-2010 07:59 AM
New (re)owner of a 61 uni-body duenas61 1961 - 1966 F-100 & Larger F-Series Trucks 3 01-14-2006 06:10 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
