1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
First project! '61 uni
Old 06-04-2013, 10:25 AM
61steven's Avatar
61steven
61steven is offline
Talking First project! '61 uni
Hello guys! I am now the proud new owner of a 1961 unibody shortbed. It's a straight six with four in the floor, not the big window cab. I picked the truck up for $700 with a clean local title(when I find it). The rust on the truck body is pretty extensive, but the frame is solid. The seat and headliner are shot but the dash is all good and all there. There is a crack in the windshield that I didn't notice till i got it home. There seems to be a repair done on the crack already. The engine might be toast. When I picked it up the valve cover was off and has a bent push rod. I will be posting pictures here pretty soon. Donations of parts and knoledge are always welcome!
Old 06-04-2013, 11:16 PM
Bill W's Avatar
Bill W
Bill W is offline
Sounds like a great project! can't wait to see some pics of it.... I just had a front windshield put in mine (Again!) cost was about 180.
Also, Welcome to FTE!
Old 06-06-2013, 10:19 AM
61steven's Avatar
61steven
61steven is offline
Im still trying to figure out a way to get pictures from my BlackBerry on to here(I recently destroyed my android phone).
Anyway, I have started to get into the truck and have broke the first bolt! It turns out that the rear end is locked up for one reason or another. I think it's the brake shoes being rusted in place due to the parking brake had been set for so long.
On the brake drum is there any retainer to remove before pulling it off? Im getting the expected resistance from it, but there is some give and spring to it!
Did these trucks come with a 9in rear end?
Old 06-06-2013, 10:24 AM
61steven's Avatar
61steven
61steven is offline
So I have more information on the truck! Could anyone tell me what the glove box tag really means?
Serial number: G10jg17523
W.B: 114
Color: B
Model: 6100
Date trans: A
Axle: 11
Max. Gvw lbs: 5000
Crt net HP: 114
RPM: 3600
DSO: blank?
Old 06-06-2013, 01:10 PM
61steven's Avatar
61steven
61steven is offline
I talked to a body shop earlier this afternoon and found out that one of the guys is selling a 4.6l running engine/tranny/wiring harness for $650 with 100k on it. Are brackets made for this conversion, or would i have to fabricate and weld something onto the frame? Also, what would that mean as far as the shift on the column since its an auto tranny?
Old 06-07-2013, 10:30 PM
61steven's Avatar
61steven
61steven is offline
Old 06-07-2013, 10:32 PM
61steven's Avatar
61steven
61steven is offline
Old 06-07-2013, 11:11 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
VIN: F10JG171523 / W.B. 114 / COLOR: B / MODEL: 6 F100 / TRANS: A Wrong code for 4 speed, should be an F / AXLE: 11 / MAX. GVW LBS: 5000 / CERT NET HP: 114 / RPM: 3600 / DSO: blank?
Welcome to FTE
1961/62: No DSO code unless the truck is a Domestic Special Order.
F10 = F100 2WD
J = 223 1V I-6.
G = Chicago IL Assembly Plant.
171523 = 1961, assembled May 1961.
114" Wheelbase.
B = Caribbean Turquoise.
F100 2WD, 5,000 lbs. GVWR
A = Ford 3 speed manual transmission, non syncro 1st gear (F = Borg Warner T-98 4 speed).
11 = Ford 9" Rear Axle / 3.70-1 / No Limited Slip / 3,300 lbs. Rear Axle Capacity.
5,000 lbs. Gross Vehicle Weight Rating.
114 net HP @ 3,600 RPM
Old 06-08-2013, 07:44 AM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Moved to proper forum. Your welcome Bill.......................lol
Old 06-08-2013, 01:18 PM
61steven's Avatar
61steven
61steven is offline
my apologizes on the serial number, i was copying it down from a picture. I went out and wrote it down by hand so this one should be correct
F10JG171523
The last owner informed me when i picked up the truck that the tranny was not stock. He changed the 3 speed out for the current 4 speed in it.
Thank you for the information.
If the rear end happens to be rusted shut, and not just frozen brake drums, what are my options? is it possible to rebuild the axle or should i just look for another?
Old 06-08-2013, 01:48 PM
NumberDummy
Correct VIN edited into post 8.
Old 06-08-2013, 02:45 PM
garbz2's Avatar
garbz2
garbz2 is offline
Moved to where it will wither and die on the vine.....
Garbz
Old 06-09-2013, 10:18 AM
37 Ford guy's Avatar
37 Ford guy
37 Ford guy is offline
Like Garbz said, you've done this guy no favors by moving his thread to the unibody section.....
Old 06-09-2013, 12:29 PM
61steven's Avatar
61steven
61steven is offline
^I would have thought that a 1961 unibody would have been just find along with the 1961-1966 trucks. More traffic at least.
Old 06-09-2013, 12:49 PM
37 Ford guy
I agree, 61steven! Did moving the thread also make your pics disappear?
There's really nothing unique enough about the unis to justify segregating them to their own forum. Even the uni owners don't frequent this section much. I would request to transfer back to the 61-66 or least post any of your issues that aren't specific to the uni in the 61-66 section. Otherwise, you'll go for days or even weeks without any response! jmho
Randy
Quick Reply: First project! '61 uni
