Value of a flathead? - Ford Truck Enthusiasts Forums
Old 06-09-2003, 10:44 AM
66MercMan's Avatar
66MercMan 66MercMan is offline
66MercMan is starting off with a positive reputation.
I am shopping for a motor for a 29 Roadster. Wondering what is a realistic cost of a flathead V8. One I am looking at, year unknown, price not yet negotiated, turns over manually, not run for countless years. Will rebuild. I'm new to the older Ford motors. How hard are these to find? What should I offer him?
Thanks in advance.
Old 06-09-2003, 11:46 AM
sosotwo's Avatar
sosotwo sosotwo is offline
sosotwo is starting off with a positive reputation.
I know up here in canada I can get a flattie for about 250 dollars
Old 06-18-2003, 01:39 PM
41Clay's Avatar
41Clay 41Clay is offline
41Clay is starting off with a positive reputation.
Check and make sure it has 24 bolts on each head, the ealier cars, some with water pumps in the head, are not a good motor for building other than to be absolutly stock. 8BA's are a little better than the ealier ones with the water outlet in the center of the head, but it's up to what you can find and want. I'd pay less than $300 for any motor unless recently rebuilt.
Clayton
Old 06-18-2003, 03:44 PM
66MercMan's Avatar
Thanks Guys, this helps.
AOD behind a Flathead ?'s mstng5point0 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 10-20-2012 03:38 PM
Info on flathead inline sixes TallPaul 1948 - 1956 F1, F100 & Larger F-Series Trucks 47 11-11-2010 01:35 AM
68' F100 4x4 flathead? liv3wire Flathead V8 & Flathead 6 6 01-17-2005 10:30 AM
flathead oil ddurant 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 05-30-2003 12:58 PM
How to identify a flathead? 51dueller Flathead V8 & Flathead 6 7 10-05-2002 01:06 PM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
ablower, flathead, ford, motor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
