Bio Diesel Newbie - Ford Truck Enthusiasts Forums
Bio Diesel Newbie
Old 06-03-2013, 08:33 AM
granny_rocket's Avatar
granny_rocket granny_rocket is offline
granny_rocket is starting off with a positive reputation.
Bio Diesel Newbie
Hey Folks,
While I'm not new to the world for Ford truck diesels, I am new to the idea and potential following thru of making bio-diesel. If I do go through with this "project" I want to go ***** to the wall. I have even gone as far as debating buying a turbo-diesel Jetta (an older on) to replace my current gasoline vehicle, assuming I can do this. Between the already incredible high mileage of the jetta and the "free" biodiesel I should theoretically be at a "0" cost for my fuel. This would also allow me to run my Powerstroker much more often without fearing the fuel bill at the pump!
I've been doing initial research on how the process works. I get you add lye, methanol and shake, let it sit then "sift". I know there is also a lot more involved like washing, etc.
SO that being said I"m looking for some web-site research. Are there good sites to get started on? I didn't see any stickies in this forum (ahem...perhaps someone could make a sticky??? LOL)
Thanks so Much
and Happy Rattling!
Al C
Old 06-03-2013, 11:35 AM
binuya's Avatar
binuya binuya is offline
binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.binuya has a great reputation on FTE.
Here's a link to what I believe, is the best place to get started:
http://www.make-biodiesel.org/
It has the latest information on everything for the homebrewer.
Good luck, and any questions along the way are answered here in this forum quickly and thoroughly.
Old 06-04-2013, 02:16 AM
genscripter's Avatar
genscripter genscripter is offline
genscripter is starting off with a positive reputation.
Since you are just starting, you could look into WVO instead of BioD. WVO is just filtered and dewatered veggie oil, and BioD is chemically treated veggie oil. The goal of running any veggie oil in a Diesel engine is to lower the viscosity of the oil to something close to the viscosity of Diesel. So, you can either heat it from the tank to the IP (WVO) or chemically treat the veggie oil (BioD). The upfront cost is more to install a two-tank WVO system, but the cost of processing WVO is nearly nothing since it is just filtering and settling. The upfront cost of BioD is less (replacing seals and hoses), but it costs more to make your own BioD in the long run.
Up to you. There are other pros and cons.
Old 06-04-2013, 08:06 AM
Christof13T's Avatar
Christof13T Christof13T is offline
Christof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant futureChristof13T has a brilliant future
I gotta agree with Gene...
Do you really want a bunch of caustic acid, and methanol laying around just waiting for a spill?
Wvo (imo) is just safer to deal with... and comparatively less expensive to process...
Granted... converting the truck is a bit more involved... addition of 2nd fuel pump, filter, and heating system...
Old 06-04-2013, 10:52 AM
binuya's Avatar
Best way to determine which route to go depends on if your driving is short trips, (5-20 miles), or longer drives. Unless most of your driving is 15-20 miles or more at a time, then biodiesel is the alternative fuel of choice.
Old 06-06-2013, 01:16 AM
I assumed anyone who is going to buy a big block Ford Diesel, is probably going to drive it more than a handful of miles a day. Having a big diesel engine as your daily driver probably isn't the best use of fuel, whatever type of fuel that is.
Old 06-24-2013, 06:30 AM
Lin19687 Lin19687 is offline
Lin19687 is starting off with a positive reputation.
I would 1st start by reading all that is in this forum and multi other web sites.
Tons of info, you just need to look
VERT Biodiesel in LA??? adambomb S. California Chapter 8 06-02-2009 10:36 AM
Hey, Austin! BioDiesel and Additives? lakerats Texas Chapter 2 12-27-2006 01:59 AM
Allergic reaction to biodiesel? nlemerise Bio-diesel, Propane & Alternative Diesel Engine Fuels 7 11-22-2006 10:26 PM
Bio-diesel OK for turbo diesel applications? Michael Sizemore Bio-diesel, Propane & Alternative Diesel Engine Fuels 8 03-17-2006 12:12 AM
Bio-diesel vs. WVO Dieseldan7.3 Bio-diesel, Propane & Alternative Diesel Engine Fuels 16 09-12-2005 08:56 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
