97 f250hd alternator 95amp to 130 amp?
Old 06-02-2013, 07:47 PM
BobbyBouchet's Avatar
BobbyBouchet
BobbyBouchet is offline
I have the 1997 f250 hd with a 95 amp. I tried doing some searching, and came up with a little bit of info, but not enough. I use this truck for plowing, more than likely will be plowing a couple of parking lots and i'd say about 30 driveways. With my 95 amp just blowing up, I was hoping someone could point me in the right direction to dropping in a 130 amp. One that I can just drop in without any kind of modification. Also, what would be a good brand. Doing searches through napa, autozone, advanced only has 95 amps showing up. Thank you
Old 06-02-2013, 09:31 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
which engine are ya working on there Bobby?
Old 06-03-2013, 02:59 AM
ArdWrknTrk's Avatar
ArdWrknTrk
ArdWrknTrk is offline
pedant
Have a look at these alternators.
You can see how they have two holes between the three pairs of fins on the front.
The diameter is 148mm, where your 95A is 135mm with four holes.
It may be you have one with 'V' legs on the front.
But I can't find a picture of that right now.
If you can tell us which mounting style your truck is, we can tell you what vehicle you need to ask for.
I would also suggest using a lower gauge charging cable to handle the extra amps.
These are inexpensive enough.
Old 06-03-2013, 06:00 AM
BobbyBouchet
Thank you for the reply!
It is the 5.8l engine
It would also be that side mount alternator.
Old 06-03-2013, 06:02 AM
BobbyBouchet
Will the difference in diameter cause any problems?
Old 06-03-2013, 06:07 AM
Evan_P's Avatar
Evan_P
Evan_P is offline
With a side mount, no. RJM sells a 160 amp alternator new for $130.
RJM Injection Tech — Side Mount 160Amp 3G
Or if you want a used one, any of these should work:
93-96 V8 Econoline with Air Conditioning or the High Output Alternator options
97-03 V6 Econoline E-Series or F-150
95-01 4.0 V6 Explorer or Ranger
94.5-97 Powerstroke Diesel F-Series
Old 06-03-2013, 06:43 AM
BobbyBouchet
excellent. What gauge wire does my truck use now, and what would be recommended?
Old 06-03-2013, 12:47 PM
Evan_P's Avatar
Evan_P
Evan_P is offline
Yours should be 4 gauge from the alt to the starter solenoid. You should replace that run with a 2 gauge one making sure you add a 175 amp fuse in line with it.
marv02
13
06-22-2017 10:39 AM
kyle j
01-28-2013 09:51 PM
v_dub_1988
1997 - 2003 F150
12-29-2008 07:44 AM
Mazda_man
1983 - 2012 Ranger & B-Series
11-08-2004 10:27 PM
bigsam
Electrical Systems/Wiring
04-13-2002 02:47 PM
Quick Reply: 97 f250hd alternator 95amp to 130 amp?
