1988 F-350 Build Thread
#31
Got the transmission pan gasket, filter, and some Indian Head today for when I replace all of the tranny fluid. Also got 8 quarts of "type F" transmission fluid because that was all the place had, so I checked 2 other places that didn't have any either. Guess I just have to wait until they get another shipment in to get the other 6 quarts...
Also got my chrome valve covers in today from Summit for the engine I'm swapping in! They look good!
#33
Got a little more paint on it, but didn't get to spend much time at all on it today. Will hopefully get the chrome valve covers on soon and get some pics uploaded!
#34
#35
#36
How is the engine oil filter arranged in your truck? Does it have a remote filter setup? The filter hits the crossmember when you put a 429/460 engine in a truck that came with a 302/351. Changing to the 7.3 diesel/7.5 gas crossmember is a major deal since it is welded and riveted into the frame.
#37
#38
Yep, pretty much all of the computer stuff and wiring are gone. No need for any wiring but ignition to the engine. Higher pressure fuel system parts are gone too.
#40
#41
When I get my current engine yanked out, I'll take a picture specifically of that and post it up for you to see. But yeah, it's not difficult.
#42
#43
Worked a little bit more on my truck today. Got the other header out, got the engine mounts loose, got the vacuum lines off, and got the few electrical bits disconnected.
Will take the hood off of the truck and unbolt the engine from the trans tomorrow. Will either yank the engine out tomorrow afternoon or Monday.
#44
Now everything is ready for the engine to be pulled. Unbolted everything, took the hood off, took the carb off, and tied up wiring and such so that it's out of the way. Was hoping to pull the engine this afternoon, but a thunderstorm moved in... Plan on pulling it out tomorrow as long as the weather holds up.
#45
