1988 F-350 Build Thread - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 06-04-2013, 08:46 PM
BigBlockF350's Avatar
BigBlockF350 BigBlockF350 is offline
BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.
Got the transmission pan gasket, filter, and some Indian Head today for when I replace all of the tranny fluid. Also got 8 quarts of "type F" transmission fluid because that was all the place had, so I checked 2 other places that didn't have any either. Guess I just have to wait until they get another shipment in to get the other 6 quarts...
Also got my chrome valve covers in today from Summit for the engine I'm swapping in! They look good!
  #32
Old 06-04-2013, 09:43 PM
RedDevil460's Avatar
RedDevil460 RedDevil460 is offline
RedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to all
Cool. Make any more progress on the new engine or not, and got any pictures of those chrome valve covers?
  #33
Old 06-04-2013, 10:08 PM
Quote:
Got a little more paint on it, but didn't get to spend much time at all on it today. Will hopefully get the chrome valve covers on soon and get some pics uploaded!
  #34
Old 06-06-2013, 11:20 PM
Got everything loaded up tonight to take to where I'll be doing the engine swap at the end of the month. Here's a little peek of the engine mostly painted up now. Still haven't put the chrome valve covers on it yet. The toolbox there is also full of stuff for the swap.
  #35
Old 06-07-2013, 11:10 AM
Sapphire Blue_95's Avatar
Sapphire Blue_95 Sapphire Blue_95 is offline
Sapphire Blue_95 is starting off with a positive reputation.
Can't wait to see the finished product!
So, now with running an older carburated engine, did you/will you get rid of all the computer stuff, or do you have to keep anything for the truck to still run right?
  #36
Old 06-07-2013, 11:53 AM
BuickBrian's Avatar
BuickBrian BuickBrian is offline
BuickBrian is starting off with a positive reputation.
How is the engine oil filter arranged in your truck? Does it have a remote filter setup? The filter hits the crossmember when you put a 429/460 engine in a truck that came with a 302/351. Changing to the 7.3 diesel/7.5 gas crossmember is a major deal since it is welded and riveted into the frame.
  #37
Old 06-07-2013, 06:01 PM
Quote:
It's just cut to allow for the oil filter to have enough room. Someone else did it, not me.
  #38
Old 06-07-2013, 06:07 PM
Yep, pretty much all of the computer stuff and wiring are gone. No need for any wiring but ignition to the engine. Higher pressure fuel system parts are gone too.
  #39
Old 06-07-2013, 06:45 PM
Fastback460's Avatar
Fastback460 Fastback460 is online now
Fastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to behold
Engine is looking good man. Looking forward to seeing this completed.
  #40
Old 06-10-2013, 09:30 AM
f150graverober f150graverober is offline
f150graverober is starting off with a positive reputation.
Thanks for sending me the link. After looking at your thread you convinced me to swap it haha. Nice truck Im subscribed cant wait to see the new motor go in. Read about fitment issues on the crossmember, pretty straight forward to cut out clearance?
  #41
Old 06-10-2013, 09:38 AM
Quote:
Sure thing. I can't wait to get the engine in there, haha.
When I get my current engine yanked out, I'll take a picture specifically of that and post it up for you to see. But yeah, it's not difficult.
  #42
Old 06-21-2013, 11:21 PM
Starting pulling stuff apart this afternoon. Got the fan shroud, radiator, transmission cooler, fan, starter, and one header off. Will be working on it more over the weekend. Hope to have some pictures up soon!
  #43
Old 06-22-2013, 09:43 PM
Worked a little bit more on my truck today. Got the other header out, got the engine mounts loose, got the vacuum lines off, and got the few electrical bits disconnected.
Will take the hood off of the truck and unbolt the engine from the trans tomorrow. Will either yank the engine out tomorrow afternoon or Monday.
  #44
Old 06-24-2013, 06:57 PM
Now everything is ready for the engine to be pulled. Unbolted everything, took the hood off, took the carb off, and tied up wiring and such so that it's out of the way. Was hoping to pull the engine this afternoon, but a thunderstorm moved in... Plan on pulling it out tomorrow as long as the weather holds up.
  #45
Old 06-25-2013, 11:12 PM
Got the engine out today! Finally...
A picture specifically of the cut cross-member for those interested in how much it needs to be cut to make room for the oil filter when swapping from a 302/351 to a 460:
Vintage Picture Thread. (WARNING: 56K ~ Picture Loadin' Death!) 76f350spercamprspeal 1973 - 1979 F-100 & Larger F-Series Trucks 97 04-03-2016 11:16 PM
Bad Habit all dressed up for a night on the town bad_habit_F350 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-09-2014 05:20 AM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 09:46 PM
D60 RSK Swap with Pics jchosler 1994.5 - 1997 7.3L Power Stroke Diesel 26 01-24-2011 07:42 PM
Car show in Bangor Maine, my dent took 2nd taxreliever77 1973 - 1979 F-100 & Larger F-Series Trucks 11 09-12-2010 03:14 PM
Tags
1988, 460, build, f-350, ford, project, thread, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
