1988 F-350 Build Thread - Page 2 - Ford Truck Enthusiasts Forums
Old 06-03-2013, 12:06 PM
BigBlockF350's Avatar
BigBlockF350 BigBlockF350 is offline
BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.
Quote:
Originally Posted by Sapphire Blue_95 View Post
Absolutely LOVE this truck!
Thanks! You've also got a sweet truck!
Old 06-03-2013, 12:14 PM
Quote:
Originally Posted by Redneckfordf2502002 View Post
sweet build thread subscribing for ideas and to see how this comes out.
Thanks Trav, glad you like it!
I like the lights in the grille.
Thanks, I really like the look. You should put them in the grille of your 88 F-150!
Old 06-03-2013, 12:19 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002 Redneckfordf2502002 is offline
Redneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputationRedneckfordf2502002 has a superb reputation
I was thinking of doing that on my 88 F150, our 89 F250 and 89 F350 plus I think it would look neat on our 02 F250.
Trav
Old 06-03-2013, 12:32 PM
RedDevil460's Avatar
RedDevil460 RedDevil460 is offline
RedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to allRedDevil460 is a name known to all
Trav
Haha, seems like you like those lights, huh Trav? I like em too. I was thinking doing something similar on mine too. They look cool.
Old 06-03-2013, 01:01 PM
damarble damarble is offline
damarble is gaining momentum as a positive member of FTE.damarble is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by BigBlockF350 View Post
Yep, they're 37" x 12.5" x 16.5" Military GoodYear MT's. I'm really liking them so far. They have great road manners, and they're pretty quiet on the highway.
That's good to know. I've heard people say the exact opposite but for the price they're really tempting. What load range? Turning them with 4.10s?
Old 06-03-2013, 04:28 PM
Sapphire Blue_95's Avatar
Sapphire Blue_95 Sapphire Blue_95 is offline
Sapphire Blue_95 is starting off with a positive reputation.
Really appreciate it! Hope to one day in the near future to have a truck similar to yours. Just not a bad thing I could say about it
Old 06-03-2013, 04:39 PM
Fastback460's Avatar
Fastback460 Fastback460 is offline
Fastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to beholdFastback460 is a splendid one to behold
Nice truck you have BigBlockF350
I have the same lights under my dash, except they are white LED's
Old 06-03-2013, 04:55 PM
Quote:
They really seem like good tires to me. I've heard they aren't great off-road, but I don't have any intention of wrecking my truck with mud...
They're load range D. 8 ply. Rated at 3850 lbs @50 PSI.
I've got 4.56 gears in my truck. Even with 37s, it's still a pretty good runner.
Old 06-03-2013, 04:57 PM
Thanks!
I looked at the blue, red, and white, LEDs. I was afraid the white might have been a little too bright and the other colors were a little more dimmed down. How are they? I'd consider switching to white ones if they look good.
Old 06-03-2013, 11:02 PM
When I do the upcoming engine swap, I'm planning to drain ALL of the fluid out of the transmission. I'll have the torque converter off to drain it, I'll drop the pan (could use a new gasket anyhow...), and I'll blow the lines out with air. I also have a new transmission cooler to put on. The cooler is slightly larger than the current unit. The current one has a tiny tiny leak in it. Not enough to even drip, but it leaves a slight oily film on everything behind it while driving... Plus, the leak could decide to get bigger at any time.
The C6 should take 14 quarts in the system, correct?
New trans cooler:
Old 06-04-2013, 04:28 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
I hope you have better luck than I did with those Military OZs
Old 06-04-2013, 07:17 AM
Thanks!
I think they look good. It's lights up the entire floor(great for when you drop something in the dark)
The only downfall is that you can't have them on very long while driving at night because it causes a glare over the mirrors, making it hard to see behind me.
I'll try to get pic of them tonight.
  #28
Old 06-04-2013, 08:43 AM
Yeah, that's what I was afraid of with the white being much brighter. The darker toned colors don't bounce around the cab as much I guess.
  #29
Old 06-04-2013, 01:22 PM
burton7.3 burton7.3 is offline
burton7.3 is starting off with a positive reputation.
What e pump did you use and how did you run the line to Make it pump fuel with the lift pump?
  #30
Old 06-04-2013, 01:53 PM
Quote:
It's just a low pressure electric pump mounted on the frame just past my tank selector valve. Right in the main fuel line to the engine. When the electric pump is off, fuel still flows through it because the mechanical pump is running. I have a 2-stop pull switch in my dash, power is given to the coil at both stops, and power is given to the electric pump at the second stop (all the way out). So, I can prime fuel to the carb before I start it by pulling the switch all the way out, and once it's running I'll switch it back to the first stop where the electric pump does not run.
Here's a picture. The silver thing is my low pressure tank selector valve, and the electric pump is to the right of it.
Vintage Picture Thread. (WARNING: 56K ~ Picture Loadin' Death!) 76f350spercamprspeal 1973 - 1979 F-100 & Larger F-Series Trucks 97 04-03-2016 10:16 PM
Bad Habit all dressed up for a night on the town bad_habit_F350 1973 - 1979 F-100 & Larger F-Series Trucks 16 05-09-2014 04:20 AM
Pics of my 1977 SuperCab 77 Supercab 1973 - 1979 F-100 & Larger F-Series Trucks 12 08-10-2011 08:46 PM
D60 RSK Swap with Pics jchosler 1994.5 - 1997 7.3L Power Stroke Diesel 26 01-24-2011 06:42 PM
New Lights on the X iamme81702 Excursion - King of SUVs 4 11-14-2010 09:52 PM
Tags
1988, 460, build, f-350, ford, project, thread, truck, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
