engine temp - Ford Truck Enthusiasts Forums
engine temp
Old 06-02-2013, 05:45 PM
TheGageinator TheGageinator is offline
TheGageinator is starting off with a positive reputation.
engine temp
My truck always runs cold. New thermostat and water pump. Any ideas?
Old 06-02-2013, 05:50 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
That looks completely normal for one of these trucks with a stock motor, if you also get plenty of heat out of the core then there is nothing wrong with your truck.
Old 06-02-2013, 07:45 PM
MeanGreen460 MeanGreen460 is offline
MeanGreen460 is starting off with a positive reputation.
What degree thermostat are you running? If your not kicking out any trouble codes I would not worry .At least your not running too hot thats the good thing .Some of those Ford factory gauges are not all that accurate .
Old 06-02-2013, 09:40 PM
BigBlockF350's Avatar
BigBlockF350 BigBlockF350 is offline
BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.BigBlockF350 has a very good reputation on FTE.
I wouldn't worry about it. It should be fine. Plus, as someone else already said, Ford gauges aren't always the most reliable.
Old 06-02-2013, 09:48 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
My '94 shorty F150 runs on the N fully warmed up, new water pump, rad and Ford 192* thermostat.
My 1990 F250 Diesel doesn't even reach the N fully warmed up, and my 87 E350 camper runs on the M-A and real gauge reading around 185-190.
Stock dash gauges in these trucks are useless. Your reading looks perfectly normal for a warmed up Ford. If your worried, get a real gauge.
Old 06-03-2013, 02:53 AM
TexasGuy001 TexasGuy001 is offline
TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.TexasGuy001 has a very good reputation on FTE.
Every truck of this era I have seen runs around the N or O.
Replacing the rear speakers in a 2010 Regular Cab propellerhead Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 14 06-22-2016 06:34 PM
1949 ford laying running boards down2earth 1948 - 1956 F1, F100 & Larger F-Series Trucks 36 09-06-2015 02:35 PM
Part identification cscott952 1987 - 1996 F150 & Larger F-Series Trucks 7 03-11-2014 11:24 PM
Pictures finally Fordmaster06 1957 - 1960 F100 & Larger F-Series Trucks 9 06-07-2012 09:16 PM
Custom Audiophile Audio/Video System in 2009 F150 jmlaudio 2009 - 2014 F150 8 09-30-2009 12:55 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
