fan comes on with a/c
The weather has been in the low 90s lately and I've noticed when I have the a/c on and the engine is fully warmed up the engine fan will come on. I think its only when I'm in traffic, not at highway speeds, but the thing that gets me is the coolant and oil temps are staying right around 190-193 degrees. It never did this last summer or the one before. Also, if I have the a/c on coming home at night, the next morning the fan will be on after a "cold" start until I get out of my neighborhood. Is this all normal?
I have to agree, I don't notice my fan as a pronounced noise at startup even with the a/c on. But yes it does activate the electric fans on my 98 neon, any time the a/c is turned on it automatically turns the electric fans on which is concurring with other post. But I never recall hearing the roaring of the fan on my truck with just a/c only. when towing and hitting @ 220 i do. Did you unplug your egr electrical connector?
Ian, have you read this entire link.
https://www.ford-trucks.com/forums/1...ed-sensor.html
The fan is suppose to come on when AC is turned on. The fan stays on to a certain duty cycle until 45mph and above, then the fan shuts down. Under 45mph, the fan will cycle duty on.
Here is a portion of a data log CSV file from my DashBoss.
Found some info in the workshop manual.
A/C Pressure Cutoff Switch — 5.4L and 6.8L
The A/C pressure cutoff switch is used to interrupt the A/C compressor operation in the event of high system discharge pressures.
The dual function pressure switch (DFPS) is used to interrupt A/C compressor operation in the event of high system discharge pressures.
- The A/C pressure cutoff switch is mounted on a Schrader valve-type fitting on the high pressure side of the A/C manifold and tube.
- A valve depressor, located inside the threaded end of the A/C pressure cutoff switch, presses on the Schrader valve stem.
- This allows the A/C pressure cutoff switch to monitor the compressor discharge pressure.
- When the compressor discharge pressure rises, the switch contacts open and the A/C request signal circuit to the PCM is interrupted. When the pressure drops, the contacts close to complete the A/C request signal circuit to the PCM. For specifications regarding operating pressure(s), refer to Section 412-00.
- It is not necessary to discharge the refrigerant system to remove the A/C pressure cutoff switch.
- The dual function pressure switch is mounted on a Schrader valve-type fitting on the high pressure side of the compressor manifold and tube assembly.
- A valve depressor, located inside the threaded end of the DFPS, presses on the Schrader valve stem.
- This allows the DFPS to monitor the compressor discharge pressure.
- The DFPS has two sets of electrical contacts. One set of contacts is normally closed and is used for A/C high pressure cutoff.
- When the A/C compressor discharge pressure rises, the switch contacts open, disengaging the A/C compressor. When the compressor discharge pressure drops, the switch contacts return to the closed position, and A/C compressor operation resumes. For specifications regarding operating pressures, refer to Section 412-00.
- The second set of electrical contacts in the DFPS is used for engine cooling fan control.
- It is not necessary to recover the refrigerant to remove the DFPS.
Turn on the A/C does the fan get loud?
Turn off the A/C does the fan quite down again?
repeat once or twice.
Could be an A/C problem causing the PCM to activate the FAN?
Its not like that though, it comes on randomly but only when the a/c is on or sometimes if the a/c was on last time I shut down the truck.
