glove box springs - Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
glove box springs
Old 06-02-2013, 04:29 PM
62ESQ 62ESQ is offline
62ESQ is starting off with a positive reputation.
glove box springs
Has anyone tried changing the glove box springs? I bought a new set and noticed that one spring has one thicker end than the other spring ends. Is one meant to go on a particular side? Since I don't have an old one on one side, it's hard to tell which is supposed to go where.
Old 06-02-2013, 05:37 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
C1TB-8106112-A Right & C1TB-8106113-A Left .. Glove Box Door Assist Springs.
Applications: 1961/66 F100/1100 / 1963/69 N/NT/T500/1100 / 1967/69 F800/1000.
Old 06-03-2013, 01:29 PM
Does your exploded view show which part number is the thicker tipped spring?
Old 06-06-2013, 12:24 PM
No it doesn't. Pic below same as 1961/63.
Old 06-06-2013, 05:04 PM
Thanks for the pic! it is helpful. After crawling around under the dsah some more, it does look now like the spring with the thicker end is on the left side of the glove box when facing the dash. I'm going to try to remove and replace the springs tomorrow, so I'll report back how that went!
Old 06-07-2013, 07:41 PM
Mission accomplished! Got the springs on without removing the glove box or the heater. Not much room for my hands under the dash while up side down. The thicker tipped springs goes on the left side as you face the glove box and the thinner on the right. The trick was to put the spring on the bottom hinge first then attach it to the top. Glove box door closes nice and tight now.
Need a glove box jrockdiddy 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 12-08-2014 02:00 PM
Locking glove box RubyRedBeast Aftermarket Products 0 08-31-2014 05:02 PM
Need help with my glove box door springs on my 59 F100. Vsanzbajo 1957 - 1960 F100 & Larger F-Series Trucks 21 03-15-2014 07:49 AM
Glove box hinge springs tip49 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 06-12-2013 01:58 PM
Glove box spring install 49f3dls 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 10-13-2012 12:45 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
