64 t-bird 390
Probably 10.1 on the CR as OEM.
Yes, premium fuel, and lots of it....
2.02/1.55 on the valves. Most FE heads are "good" and will support a fair amount of power over the stock outputs. However, your heads will have the buttery valve seats of yesteryear, when manufacturers relied on lead in the fuel to protect the seats--sorta. Valve jobs at 40,000 miles were not unheard of in the day. Most lasted much longer, of course, but remember, in '64 a car was pretty much junk at 100k.
The cork in an FE motor like that is the exhaust manifolds. Look at 'em. They look more like plates bolted to the ports to keep them closed up than manifolds....
Yes, 2 bolt mounts are early mounts, '65 was the change.
This thread is going the other way--truck FE into 'Bird, but it has a lot of info:
https://www.ford-trucks.com/forums/1...-a-t-bird.html
FE info, some typos:
FE Series Engine Specification Chart
Octane requirement will depend on the cam used. If you keep the stock cam, then yea, it'll need 91-93 octane. Swap the cam to something like Crane's 272* Energizer and it'll be fine with 89 and 12* initial timing.
I was told it has 268h cam. he showed me the cam card. it idles real nice. kinda aggressive but not to radical you know. im just spooked bout needin to run 91 or 93. can I get away with runnin 87 or 89 on this engine? moneys tight so every penny counts and 87 is $3.69 91 is $3.99
If it's a "P" code '64 390 the CR will be 10.5:1
If it's a "Z" code '64 390 the CR will be 10.1:1
This is assuming it's all original and stock.
It's funny that aside from having to deal with ethanol blended gas,(and the problems that brings) the "crap gas" we have today seems to work fine with 9-11 to 1 compression ratios, and at a lower octane than the "good gas" of the 1960's
Montana does that mean it came out of a cop car? the seller said a t-bird. were there any t-bird cop cars?
