Pic request 78/79 bronco 4" lift - Ford Truck Enthusiasts Forums
Old 06-02-2013, 09:23 AM
Cool1996's Avatar
Cool1996 Cool1996 is offline
Cool1996 is starting off with a positive reputation.
N00b question. I am going to install a 4" lift on my Bronco (freebie) and im trying to decide what size tires I will be running. I was decided on 35's until i saw a bronco with 35's and no lift, so i just want to make sure.
Please post up your trucks. Ideally, i would like to see a 4" lift on 35x12.50's with 15x10's but ill look at everything. It will be mostly a pavement princess, because the truck is too nice and original to beat up in the trails, so im not too concerned about stuffing the tires when articulating. Thanks!
Old 06-02-2013, 01:13 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Check the pictures in this link: http://www.ford-trucks.com/forums/10...oncos-172.html go from the page I sent you back, checking the latest ones first, there are several with configurations close to what you're asking so you'll get the idea.
Old 06-02-2013, 05:53 PM
MadMatt65's Avatar
MadMatt65 MadMatt65 is offline
MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.MadMatt65 has a good reputation on FTE.
One of my old 79 Broncos had a 4" lift and 36" RVT's on 15x12 wheels when I got it. They cleared with no problems....even getting a little crazy!! That's what I love about the 78/79 Broncos and 70's Ford trucks.....they had that big wheel opening!! Remember, there is a lot of axle movement on that coil spring front end. You can "fit" a 35" on a stock suspension, but if you do anything off road....you have a good chance of stuffing a tire into a fender!
Old 06-02-2013, 05:56 PM
MadMatt65's Avatar
36" RVT's.......Boy , I'm showing my age!!
Old 06-03-2013, 07:13 PM
GruesomeJeans's Avatar
GruesomeJeans GruesomeJeans is offline
GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.GruesomeJeans has a spectacular reputation.
Sorry Encho I can't miss the opportunity to show off TGM
TGM will fit the bill even if it isn't the lift you mean.
78, with a 3" body lift which means, your bronco will look very similar but with more suspension showing. Seeing as the OEM body bushings are about 1" anyways I can say it's about 4".
35 inches of beautiful Wrangler MTR Kevlar rubber. 15 inch steel black rims that are 11 inches wide, the tires are 12.5.
Even dirty that are awesome.
Even with stock suspension the tires will tuck in nicely.
I couldn't and still haven't ever gotten this to bottom out.
I also have the stock front and back stabilizer bars. I love to show off my truck and the picture thread that Mr. Encho posted will have a lot of mine. Cruising first to last would take a while but it is worth it.
Old 06-06-2013, 03:22 PM
harleydeen98258's Avatar
harleydeen98258 harleydeen98258 is offline
harleydeen98258 is gaining momentum as a positive member of FTE.harleydeen98258 is gaining momentum as a positive member of FTE.
here's mine 4"s on 35x12.5x15 on old school 15x10's
and here she is behind my stock height '93
Old 06-06-2013, 03:56 PM
Harley, I have to say, that is a sexy bronco.... It does look like you have a bit of a saggy *** though Probably just needs an Add-A-Leaf though to stiffen it a bit.
Old 06-06-2013, 09:47 PM
Cool1996's Avatar
awesome! sell me your wheels! ive been looking for a set of 15x10 turbine wheels with no luck...do you have radius arm drop brackets?
Old 06-06-2013, 09:58 PM
Judging by the pictures and the angle of the radius arms, I would say he has some sort of drop bracket. I like the look of those Turbine rims but they are getting hard to come-by.
Old 06-06-2013, 10:53 PM
Cool1996's Avatar
Im not sure if my freebie 4" lift has drop brackets or not, since i havent opened the boxes yet...lol
there is a company in Royal Oak Michigan, by me, that refinishes and sells turbines. they have a set of 4 15x10 5x5.5 for $2000. excuse me while i puke
Old 06-19-2013, 11:09 AM
Sorry for the late reply, Thanks for the compliments folks. No the radius arm brackets are stock. The Turbines took me a couple of years to find. I've had them on the '79 now for a couple of years and I have still continued looking for 1 more for the spare to match. I have found them on Ebay for a price that would cost me more then a brand new set of 35" tires...
Old 06-19-2013, 11:10 AM
If these guys sell on Ebay they might be the ones I'm talking about...cause the price sounds familiar...
Old 06-19-2013, 11:13 AM
Also if your not set on 15x10s, I saw an ad on craiglist the other day under ford truck parts where a guy is parting out a early 70's F series 1/2 ton with turbine wheels. Instead of black like mine they are red, but look to be 15x8...
37 inch tire gearing 61 F250 1978 - 1996 Big Bronco 1 01-17-2017 06:57 PM
red excursion with 4 or 6 inch lift pics ccllud Excursion - King of SUVs 17 08-14-2016 08:52 PM
1978-79 lifted f150's lonerangermotors 1973 - 1979 F-100 & Larger F-Series Trucks 32 04-03-2013 10:17 PM
Lets see some lifted SuperCabs!!! AntiHero55 1973 - 1979 F-100 & Larger F-Series Trucks 69 10-22-2012 09:19 PM
4 inch lift with 35's? lamenytro 1987 - 1996 F150 & Larger F-Series Trucks 16 09-22-2011 03:16 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
