94 F150 Running Rich - Ford Truck Enthusiasts Forums
Old 06-01-2013, 09:04 PM
Boger Boger is offline
Boger is starting off with a positive reputation.
I have 1994 F150 XLT 5.8
Just bought it (you guys have to love these post).
Went out to start it today sat for about 24 hours since I bought it. Wouldn't start first 5 second crank. 15 seconds of cranking later it started up but man it was puffing more black smoke than I have ever seen.
Let it idle for about 15 minutes it died twice. I then drove it around the block parked it let it idle 5 more minutes. It stopped running rough and sputting idled normal.
I then pulled out of the driveway and floored the gas, it scared me there are 2 50 black marks in the road from the amount of rubber that hit the ground.
Tried to do it again (i'm 22 what can i say) and it just felt down on power and felt like I was towing a trailer. But it was not misfiring.
I also drove this truck for over a hour before I bought it, it never behaved like this.
The only difference between today and yesterday is it rained today.
Now I do have a 94 f150 xlt with the 5.0 so I was curious as to were I should start and if parts would swap from one truck to another? The engine through a rod out the side of the oil pan on my way home from work.
I have not pulled codes, I will do it on Monday.
I have no clue where I should start and what parts I can swap over if they may be the cause. :/
You guys have helped me out before, and I feel you can help me out again. I got myself into a pinch here....
Old 06-03-2013, 01:27 PM
Just a little update, went to pull codes...There were none stored or active let the truck run for 35 minutes was puffing smoke at start up and then it stopped and ran fine.
The injectors seem a little noisy so I was thinking about check those out. Otherwise I am thinking the fuel return line may be clogged and I am going to be looking into that Thursday.
Any other ideas where I should look for potential problems?
Old 06-03-2013, 02:29 PM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Check fuel pressure. That will let you know actual pressure. Also, pull a spark plug or two or all 8, and check condition. Pull cap and rotor. Clean carbon from contacts. And last, but not least....its a 94, take the time and inspect ECM (PCM). No codes after all those symptoms makes me wonder. I have my own saga of ECM problems now and it would only throw EVP code 327. It was 2 badly burned capacitors. The truck would either run well enough to drive 1 day and then poor enough for maybe a month or 2 poorly enough not to dare pull onto a city street.
May want to inspect O2 sensor and if it's more than 3 years old, its due as it degrades not only with boiling exhaust but with age. Its an Emissions part, federally mandated so no sales tax or at least not here in Missouri. Is exhaust new? If OEM from '94, Cat(s) could be partially melted and/or plugged.
Old 06-03-2013, 03:02 PM
Checking the pcm seems like a good idea, I also should say this truck has the original Catalytic Converter on it. Have not checked the condition of the O2, but it does it typically right at start up and I thought the PCM wont take readings from the o2 till its warmed up?
And on the PCM, I am assuming if it is bad or burnt up I cannot use the one from my other truck seeing as one is 5.0 and one is a 5.8?
Old 06-03-2013, 04:23 PM
Also, FPR could be bad. Pull vacuum line off and check to see if there is fuel coming out or in the vac line.
The ECM front the 5.0 could, but it's gonna run lean. I wouldn't suggest it.
Old 06-08-2013, 08:37 PM
Alrighty gentleman, I got codes!
565 Canister purge circuit failure
173 HO2s System Indicates Rich
212 Loss of ignition diagnostic module input to pcm/spout circuit grounded
332 Insufficient EGR flow detected
I should also state that when I put my truck in reverse it blows the fuse for the gauges, so I think my problem may be electrical.
I'm not sure where to start with these. Oh the joys of being color blind.
Help please! 351W ho Jacobhorn5 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 14 11-12-2015 11:47 PM
SURGING idle fordboy97 1987 - 1996 F150 & Larger F-Series Trucks 3 11-12-2015 02:28 PM
Intermittent problem Skyhawk Greg 1994.5 - 1997 7.3L Power Stroke Diesel 73 09-15-2014 11:29 AM
Strange idle then no start. roostonu 6.0L Power Stroke Diesel 16 08-07-2014 05:51 PM
Stalling out issue Carter78F150 1973 - 1979 F-100 & Larger F-Series Trucks 9 05-18-2013 09:44 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
