55 F500 first timer - Ford Truck Enthusiasts Forums
55 F500 first timer
Old 06-01-2013, 12:30 PM
tnguynaford's Avatar
tnguynaford tnguynaford is offline
tnguynaford is gaining momentum as a positive member of FTE.
55 F500 first timer
I bought a 55 F500. Common story I suppose. Rusted tight Y block, 292 I am guessing at this point... 4 speed trans and six 5 lug 20 inch widow maker wheels with every tire dry rotted junk. Frame seem to be in good shape. Its all there for a Restoration. I would like to move the 55 body to a later model chassis complete with drive train, around 2000ish. Have been considering the ranger, explorer and Dakota as wheel bases seem usable but I don't know about hub width or how well body would fit. I am looking for advice here and hope someone knows if these are good or bad ideas. I don't want to cut and splice frames if I can avoid it. I am OK with fabbing mounts if it is an option. Will the body line up OK or is it a waste of time to keep these in mind. And any other suggestions are welcome
Old 06-01-2013, 12:48 PM
h2omelon's Avatar
h2omelon h2omelon is offline
h2omelon is gaining momentum as a positive member of FTE.h2omelon is gaining momentum as a positive member of FTE.
Cool project! Are you going to keep it a dually?
Old 06-01-2013, 12:53 PM
Still undecided on dually. I have seen some cool ideas for it though. Have been leaning toward rat rod pickup style though
Old 06-01-2013, 01:32 PM
Awesome truck you have there melon!
Old 06-01-2013, 03:13 PM
harleymsn's Avatar
harleymsn harleymsn is offline
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
Well you have come to the right place for info, but I don't think that you will get the suggestions you want to hear. Basically, frame swaps are very rarely ever successful, unless you have lots of experience, equipment, time and $$$$$$$. Since you already admitted that you are not an experienced fabricator, I believe that you would be in over your head with the frame swap idea.
If you want and F100, it is best to actually start with and F100. The larger trucks are sometimes easier to find and almost always cheaper to buy. There is a reason for that, based on modification cost. You have what looks like a workable project there and the truck is a good candidate for an updated drive train and you could swap out the rear end and front axle to get rid of the widowmakers.
Old 06-01-2013, 04:31 PM
Thanks Harley. I want to hear the truth. Not just what I want to hear. I appreciate the input. I had an idea that may be the answer I was would get. From what looking I have done, it seems the original frames for these trucks were fairly straight and flat from F100 and up and the later model frames seem to have a lot of dips and rises. Which would probably make for a difficult body alignment. Am I correct there?
Old 06-01-2013, 04:39 PM
I have heard the mid 70s ford frames work well for this. Any thoughts there?
Old 06-01-2013, 06:16 PM
h2omelon's Avatar
You could build a frame for a few hundred in materials. Just have to source the front suspension and rear axle. This was my 92 Mazda all 2x3 3/16 wall tubing. You can build it to suit your needs.
Or you can modify the stock frame to suit as I did on the F1
Old 06-01-2013, 08:32 PM
I don't think my skills are at that level yet. But it is an idea worth considering. I am a good learner. Thanks for the idea. And beautiful truck you have there.
Old 06-02-2013, 01:44 AM
teardropty's Avatar
teardropty teardropty is offline
teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.teardropty has a very good reputation on FTE.
Welcome to the madness! Honestly, I would find a good frame setup for a F250 from 53-55. They come up on CL and ebay all the time. You could buy one for a few hundred. Move all the sheet metal/cab/engine over from the F500 and have a running truck. Dealing with the widowmakers and the heavy frame can be time/money consuming. Just my .02. Good luck!
Old 06-02-2013, 07:36 AM
harleymsn's Avatar
Quote:
Teardropy had a pretty good suggestion about the 53-55 F250 frame, but of course I don't see too many of them pop up in our area. I noticed the plate on the truck, are you in Putnam county?
Old 06-02-2013, 11:09 AM
Thanks teardropty. Well said "welcome to the madness" lol.
Harley- I am in Cumberland Co. The truck came from Putnam. It has been left to sit for about the last 18 years. The tag expired in 95 so I am guessing that was the end of its career on the farm. It was driven to its parking spot and left to solitude among the trees. He said he brought it down from Michigan to Tn in 1986.
She is pretty solid for the age. Right fender need replaced and the lower panel behind the bumper looks to be finished but so far the rest seems to be good. One small spot in the floor pan on passenger side around the frond cab mount about the size of a baseball, but the mount itself seems to be solid still.
Old 06-02-2013, 12:21 PM
harleymsn's Avatar
Cool, I'm in the NE corner of the county, out past the Genesis "Check In Station". I'd like to take a closer look at that truck. maybe bring Edith by for you to get some ideas.
Old 06-02-2013, 01:24 PM
That would be cool! I will pm directions.
Old 06-08-2013, 12:57 PM
Smile
Well I finally got one side of rear brake unstuck and turning now. Drive shaft spins when I turn it so at least I know diff isn't locked up. Don't know if it is any good still but turning is at least a good sign
Need help Cobwebman 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 08-28-2016 12:26 PM
1996 F250 PS Diesel towing capacity question cjaghblb 1994.5 - 1997 7.3L Power Stroke Diesel 7 04-30-2016 10:10 PM
47 Merc Panel Powerhour 1947 and Older Ford Trucks 3 09-28-2015 01:40 PM
53 Air Dam and 55 Radiator Support on a 55 F100 TxF100 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 06-11-2014 08:47 AM
Which one and why? ProjectF1056 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 02-18-2007 10:45 PM
Tags
1955, 48-56 f series, f100, f500, fat fender, ford, frame swap, project, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
