55 F500 first timer - Page 3 - Ford Truck Enthusiasts Forums
55 F500 first timer
  #31
Old 06-22-2013, 08:39 PM
tnguynaford's Avatar
tnguynaford tnguynaford is offline
tnguynaford is gaining momentum as a positive member of FTE.
Grace runs!!!! I finally got to hear her run just now!!
  #32
Old 06-22-2013, 08:58 PM
topmoo's Avatar
topmoo topmoo is offline
topmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant futuretopmoo has a brilliant future
Congratulations! Not bad for sitting for 18 years! Good luck with it.
  #33
Old 06-22-2013, 09:03 PM
Thanks topmoo!
  #34
Old 06-22-2013, 11:25 PM
First time running in about 18 years. Has an exhaust leak at cross over tube. Held 60 psi oil pressure. I had to click on words to get video to play.
  #35
Old 06-22-2013, 11:47 PM
I spent some time today trying to learn what voltage the truck is set up for now. I finally figured out that although po had installed a few 12V items it is still for sure 6V pos ground. I didnt have a 6V battery so I hooked battery charger to the cables to test guage cluster and lighting. And the plug wires were on wrong and they put dizzy in 180 degrees out. That is why cap was turned 180 degrees from it proper position and the new points they installed were burned up. So, new points, rewire plug wires, I only had a 12v battery and a 12v coil with built in resistor so I isolated the cranking system and ign system with jumper wires, new fuel line and filter feeding from a gas can she came to life!
  #36
Old 06-27-2013, 10:53 AM
Cranked her up again last night. Such a good feeling to hear the old Y Block run The parking brake linkage is free and works good now. Was fortunate to get clutch to unstick last night. Rear is up on blocks with wheels removed so I ran through the gears. All was smooth and no noises. Wish brakes were fixed and I had some good wheels and tires. But I am happy with progress so far.
  #37
Old 06-27-2013, 10:58 AM
  #38
Old 06-27-2013, 12:44 PM
Rojak Rojak is offline
Rojak is gaining momentum as a positive member of FTE.Rojak is gaining momentum as a positive member of FTE.
You're not excited are you? I really like the videos of the old workhorses coming back to life. Thanks for posting. Looking forward to the first drive video!
  #39
Old 06-27-2013, 01:41 PM
I think at this point, excited may be an understatement... lol
  #40
Old 07-09-2013, 12:10 AM
widowmakers? now I see
Ok, so I decided to dismount one tire from the widow maker wheel tonight. I have change lots of the old tube type with the ring on the outside but this was a new experience. I didn't help that they have been on for many years rusting. I spent a good 2 hours with the tire hammer and looking at it trying to figure out how it comes apart. I finally got the smaller side off but the larger side is still rusted to the tire. I am letting it soak with diesel fuel as I found years ago that it makes a good penetrating lube for old throw away tires. Now that I can see it, what a cheesy design. I cant believe anyone ever thought that up much less thought it was a "good idea". I expected a more pronounced hook to hold the 2 halves together. There ceartainly is no room for error.
I thought I might use them since finding alternatives is so costly and difficult, but I am definitely have 2nd thoughts now.
  #41
Old 07-09-2013, 05:55 AM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Do yourself a favor. Chain them together tightly and heavily and lay them on the lawn dangerous-side-up before letting air out of them. They are known to be likely to seperate during pressure excursions, low pressure being apparently less "grip" for the two halves. Heck, they've been known to blow while rolling down the highway. I had a boss whose father in law was killed when one blew next to his car. Came right through the car and crushed him dead, kept right on going. With this in mind, I chained mine with 3/8" heavy weld link and doubled-up grade 8 bolts and heavy washers prior to removing them from the vehicle.
  #42
Old 07-09-2013, 11:56 PM
After seeing how these wheels are built, I don't plan to use them. I am looking into axle possibilities for swapping. I want to keep a solid beam axle in front but they are hard to find locally. I have found a front and rear that match and will be 8 lug from and early 60's model, but I think I want to look at a few motorhome chassis before I commit.
several years ago I drove a 91 F450 super duty that had a solid beam axle in front. I wish I could find one of those for a donor truck.
  #43
Old 07-16-2013, 07:41 PM
lucked up on some 19.5 wheels!
Still ain't got brakes fixed, but I had to see how she would look.
  #44
Old 07-16-2013, 08:33 PM
Nice to see the wheels are working for you. There's that hood emblem that I need! If you find another one of those, holler.
  #45
Old 07-16-2013, 08:39 PM
I will keep watch for one
Need help Cobwebman 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 08-28-2016 12:26 PM
1996 F250 PS Diesel towing capacity question cjaghblb 1994.5 - 1997 7.3L Power Stroke Diesel 7 04-30-2016 10:10 PM
47 Merc Panel Powerhour 1947 and Older Ford Trucks 3 09-28-2015 01:40 PM
53 Air Dam and 55 Radiator Support on a 55 F100 TxF100 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 06-11-2014 08:47 AM
Which one and why? ProjectF1056 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 02-18-2007 10:45 PM
Tags
1955, 48-56 f series, f100, f500, fat fender, ford, frame swap, project, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
