Engine Replacement Opinions - Ford Truck Enthusiasts Forums
Old 06-01-2013, 11:54 AM
mdlave mdlave is offline
mdlave is starting off with a positive reputation.
<hr style="color:#D1D1E1; background-color:#D1D1E1" size="1"> Well, it looks like my 460 needs some serious valvetrain work.
If it looks like I'm getting above $500 or so just in parts (assuming I can do the work myself, it may be better long term to just replace it. I'm looking at a few choices:
1. An already built and running 460 - $1200
Good: upgraded cam, intake, and carb, all specs, high quality performance parts
Bad: From a jet boat, so I'm sure it has seen plenty of vigorous use, and hours on it are unknown.
2. An engine from these guys (cmengines.com) - $1600
Good: C9ve heads, 12 month warranty, reputable, highly ranked company
Bad: A running engine could be pulled for much cheaper.
3. A craigslist engine - $600
Good: Runs well, cheap, less than 100k
Bad: Don't know anything else about it.
Any thoughts, especially on things I haven't considered?
Old 06-02-2013, 11:58 AM
V10man's Avatar
V10man V10man is offline
V10man is gaining momentum as a positive member of FTE.V10man is gaining momentum as a positive member of FTE.
well here are my thoughts...
#1, boats usually run at high rpm. Cam and such may be set up for that. May not do so well in a truck
#2, if that is a long block with the C9 heads watch out on the compression ratio. Needs to be 9.5 or less for pump gas. Did they install hardened valve seats on the exhaust?
#3, who knows what you're getting
Old 06-02-2013, 12:52 PM
Thanks, good info.
1. Didn't think of that. I'll look into it.
2. This engine is supposed to be stock replacement for a 1969 or 1970 passenger car, so original manufacturer's specs.
3. I agree. Big negative.
Old 06-02-2013, 08:10 PM
This is the cam in the marine engine.
http://www.summitracing.com/parts/cca-34-225-4
Looks like it would be a decent street cam?
Parking Brake Shoe replacement GK4x4 1999 - 2003 7.3L Power Stroke Diesel 8 02-09-2015 05:13 AM
1988 f350, 460 Engine misses under load sloburban 1987 - 1996 F150 & Larger F-Series Trucks 22 10-25-2014 06:50 AM
Radiator help please natira121 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 07-31-2014 04:52 PM
Good price for H&S Black Max / Mini Max w/ and w/o delete jdenny21 6.7L Power Stroke Diesel 13 09-22-2012 10:10 AM
how to determine which econolines are interchable: teressaluhaorg 1968-2013 Full Size Vans 4 06-01-2012 01:24 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
