Washington Chapter Washington Chapter
Join Chapter, Leader: Yahiko
Building a new motor
Old 06-19-2013, 07:15 PM
oddfordjunkie's Avatar
oddfordjunkie
oddfordjunkie is offline
My 351M finally blew so I'm building a 460.
Already have motor, belt drive timing conversion with 20deg of cam adjustment, cam, lifters, 1.8 ratio stainless roller rockers, valve covers, intake, full gasket set, HVHP oil Pump, HD shaft
Ordering aluminum heads.
Looking for good headers (78 2wd 460 auto) I can modify and coat but must be one piece flange, thicker the better.
Debating on which style of water pump to run and which accessory style.
Can't figure out how to post an F-ing pic on this site
Old 06-19-2013, 07:20 PM
BruteFord's Avatar
BruteFord
BruteFord is offline
These are the shiznit L&L Products
1/2" flange, 14 gauge tubing, very well made, BUT $600
Old 06-19-2013, 09:40 PM
oddfordjunkie
Occasionally nice sets of Sanderson headers come up on EBay for cheaper than that, the ceramic coated block huggers are nice but if money wasn't an issue I would order Doug Thorely tri-Y coated.
Old 06-20-2013, 02:45 AM
joshofalltrades's Avatar
joshofalltrades
joshofalltrades is offline
i can't help you on the parts, but for posting pics here, all you have to do is upload your pics to photobucket or another hosting site, then link to them here, preferably with the [img] code around the links so it shows up in the text as a pic not a link
Old 06-20-2013, 02:46 AM
BruteFord's Avatar
BruteFord
You can also upload to the gallery here and link that way
Old 06-20-2013, 03:06 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
Here is the How To post Photos to FTE thread.
https://www.ford-trucks.com/forums/1...he-forums.html
Grrr. I have a bloody eyeball early Dr appointment in the AM.
Sean
Old 06-20-2013, 03:09 PM
GruesomeJeans's Avatar
GruesomeJeans
GruesomeJeans is offline
Sean
Uhh a bloody whoda whada?
I got myself some Hooker Headers from eBay, oddly enough it was from the summit seller but it was a lower price than on summits parts catalog... The flanges seem pretty thick and the pipes are nice but I don't know headers like you guys might but they might be worth looking into.
Old 06-20-2013, 03:21 PM
oddfordjunkie
I've been watching them on EBay and already ordered a couple things from Summit that way, was hoping tofind a good used set, I have a guy that does Vera-coating so getting a good set blasted and coated isn't an issue
Old 06-20-2013, 05:49 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
I was thinking of having the outside of my turbo exhaust side housing
coated if I can find an extra one to have them work on.
This is who I was thinking of do it.
Jet-Hot Ceramic Coatings
I am not after the look but keeping the heat out of the engine compartment.
Sean
Old 06-20-2013, 06:25 PM
oddfordjunkie
Vera coating is a fairly new thing but the durability is bet than Jet coat. I just happen to know the only guy in western wa that does it.
Old 06-20-2013, 06:42 PM
Yahiko's Avatar
Yahiko
Yahiko is offline
How is it for holding heat to one side?
Because that is what I need it to do.
Keep the heat in the turbo and out
of the engine bay.
I would be willing to look into it.
Sean
Old 06-20-2013, 08:00 PM
oddfordjunkie
Have been trying to do responses on my phone on the go and misspelling quite a bit.
Cerakote is the correct name of the coating. They have MANY different styles, everything to gun coatings to Piston coatings and friction coatings, headers, chemical resistance ect ect
Old 06-21-2013, 02:59 AM
Yahiko's Avatar
Yahiko
Yahiko is offline
The guy that you know is local I take it?
Can you put me in contact with him?
Thanks
Sean
Old 06-21-2013, 03:07 AM
oddfordjunkie
He's just north of woodenville on 522, will get his contact information for you tomorrow.
Old 06-25-2013, 08:30 PM
oddfordjunkie
Sorry it took so long, been busy.
The business number for the Cerakote guy is 866-774-7628
Found out the motor I bought to use the short block was junk, looks like it had spark plugs come apart in 4, yes 4! of the cylinders and the pistons like like ground beef. But the guy I bought it from is refunding me cause he thought it was a good motor, it's nice to find honest people.
Myfreeford
11-15-2011 03:07 PM
Cutls67
Ford Truck Parts for Sale
04-02-2010 11:50 AM
solidrunner
01-19-2008 11:31 AM
TMI
12-21-2004 09:44 AM
460Gene
10-17-2004 12:01 AM
Quick Reply: Building a new motor
