1964 f250 with a 292 y block want to upgrade to 4 bbl - Ford Truck Enthusiasts Forums
Old 06-01-2013, 02:12 AM
raider69guy raider69guy is offline
raider69guy is starting off with a positive reputation.
I have a 1964 ford f250 with a 292 y block in it i would like to upgrade the intake manifold and put a 4 bbl carb does any body have any ideas please help
Old 06-01-2013, 02:23 AM
i need some advise on this please help!!!!!!
Old 06-01-2013, 06:22 PM
tomfiii tomfiii is offline
tomfiii is starting off with a positive reputation.
go to
Y-Blocksforever Forums
there you can read to your hearts content and ask questions on 4 bbl's
Old 06-03-2013, 07:25 AM
bjmayberry2's Avatar
bjmayberry2 bjmayberry2 is offline
bjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud ofbjmayberry2 has much to be proud of
Find an old junk yard and start looking at cars. 292 & 312s both came out with 4 barrels in some models. If you find them it's just remove the 2 barrel manifold, add new gaskets and install. I run a Holley 390 CFM on my 272.
BJ
Old 06-24-2013, 01:18 AM
NONclow NONclow is offline
NONclow is starting off with a positive reputation.
ECZ-9425-A: small ports, matches early heads better, older "teapot"/"birdcatcher" carbs are harder to find parts for also need an adapter plate to use anything but
ECZ-9425-B: larger ports, better matched to ECZ-G or similar heads, AND they accept modern Holley square flange carbs.
I also used a 390cfm on mine...got three 94's on it now
Old 06-24-2013, 07:25 PM
stoffer's Avatar
stoffer stoffer is offline
stoffer is starting off with a positive reputation.
back in high school, I used a 2 barrel to 4 barrel adapter on my stock 2 barrel intake, and added a Holley 390
it really woke my ol' 292 up
1964 F100 292 Y Block Water Pump vze2c2gb 1961 - 1966 F-100 & Larger F-Series Trucks 25 07-11-2016 10:44 AM
WTB: 1964 Ford F100 292 Oil Dip Stick SanDogDewey WTB - Parts & other 0 02-01-2016 10:00 AM
64' F100 Scottbmcd 1961 - 1966 F-100 & Larger F-Series Trucks 10 08-10-2014 11:09 AM
1964 f100 engine swap kssouth 1961 - 1966 F-100 & Larger F-Series Trucks 8 09-16-2005 06:30 AM
1964 f-250 292 question killerkjn Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 7 12-05-2004 04:52 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
