Decode help (sry -I know it's been done) - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 06-01-2013, 12:46 AM
JoeD500 JoeD500 is offline
JoeD500 is starting off with a positive reputation.
Here we go:
I THINK it is a 1966. She is mostly scrap but I am pulling parts. It is a Ford F600 4x4. Has the Rockwell 233 T-Case and 7.20 ratio rear end. The question I have is the front axle.
First of all, I have the T.case & shafts off, but the joint at the front axle which the drive shafts attaches to spins free even when the manual locking hubs are to the lock position? any ideas why this may be?
Secondly, If there is serious internal damage in the axle/diff, I was hoping someone here with more knowledge than I could identify what model front axle I should be looking at as I have yet to find any S/N on it.
Codes are as follows:
F60ECJ14783
T32 T F600 D 8 4 66
19500 182 3800 B66753
Then on the sun visor is a sticker that says :
"NAPCO POWER-PAK" which then has a small diagram of how to use the all wheel drive and shift the T-case.
Again, any info from the above codes would be appreciated.
Joe.
Old 06-01-2013, 01:30 AM
SGT DuckButter SGT DuckButter is offline
SGT DuckButter is starting off with a positive reputation.
This sounds like a job for,,,, NumberDummy
Old 06-01-2013, 08:14 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
With a VIN of F60ECJ14783, it's not a 1966, nor is it factory 4WD, as it was first introduced in 1971 F600's (VIN series codes F65 & F66).
VIN series code: F60 = F600.
E = 361 2V FT engine.
C = Oakville Ontario Canada Truck Assembly Plant.
J14793 = 1970.
'71 Ford F600 -Front Diff JoeD500 Large Truck 1 06-18-2013 11:25 PM
turn a d44hp into a d44lp flaboy1979 1987 - 1996 F150 & Larger F-Series Trucks 1 12-22-2012 10:34 AM
Slop in front output of t-case landgreen 1999 to 2016 Super Duty 6 02-28-2012 10:04 AM
Trans -> T-case leak, any ideas? chuck864x4 1987 - 1996 F150 & Larger F-Series Trucks 2 06-22-2010 08:00 PM
79 f600 4x4 winch truck to buy or not to buy ford784x4 Large Truck 2 06-12-2010 03:34 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
