what is this? - Ford Truck Enthusiasts Forums
what is this?
Old 05-31-2013, 08:51 PM
TheGageinator TheGageinator is offline
TheGageinator is starting off with a positive reputation.
what is this?
What is this thing? Looks like a sensor or solendoid that has one vacuum line to the TB and one line to the vacuum canister. There is a slight hissing coming from it.
Old 05-31-2013, 08:53 PM
My truck sometimes dies right after starting. If I give it some gas it will stay running fine. I was thinking maybe this thing was leaking and the vacuum leak caused the truck to die?
Old 05-31-2013, 09:33 PM
mpc07005's Avatar
mpc07005 mpc07005 is offline
mpc07005 is starting off with a positive reputation.
Vapor Canister Purge Valve. Doubt it's causing your dying issue, as I believe its just upstream of measurement points depending on year (IIRC).
-Mike
Old 05-31-2013, 09:46 PM
My truck is a 1994 . can I block off this thing at the TB and leave the electrical connector on?
Old 05-31-2013, 11:52 PM
I found my answer on the inter web. Thank you for telling me what that Thing was. I found out that is used to burn the built up fuel tank vapors through the tb. If the vapors do not get released, bad stuff will happen. I am going to block off the hole at the throttle body and just vent the canister to the open air until I buy a new solenoid
Old 06-01-2013, 07:28 AM
mpc07005's Avatar
For the dying, check your Idle Air Control, Throttle Position Sensor, Fuel Pressure, Engine Coolant Temperature sensor, Manifold Air Pressure, thermostat, and maybe you Air Charge Temperature sensor, in that order. oldfuelinjection.com has testing procedures for the sensors.
-Mike
Old 06-01-2013, 11:03 AM
Thanks man I will check those! I will update when I figured it out
Ported Vacuum Switch devino246 1973 - 1979 F-100 & Larger F-Series Trucks 8 09-20-2013 09:18 PM
Vacuum Question jgavac 1973 - 1979 F-100 & Larger F-Series Trucks 12 12-25-2011 04:23 PM
What is the purpose of this vacuum line (diagram included) MitchD Ford Inline Six, 200, 250, 4.9L / 300 25 01-06-2011 04:27 PM
Vacuum line Question TexasTrash 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-09-2010 11:51 PM
Anyone Tell Me Where This Vacuum Line Connects (2004 5.4 3V)? DRM2004 2004 - 2008 F150 9 04-22-2007 10:10 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
