Ride not so great - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Ride not so great
Old 05-31-2013, 11:29 AM
2012 SD Snowbuster's Avatar
2012 SD Snowbuster 2012 SD Snowbuster is offline
2012 SD Snowbuster is starting off with a positive reputation.
Ride not so great
I understand this truck is a SuperDuty and not my old F150 that honestly rode like a caddy. I just figured the newer Super Duty would ride better than my 2004 F250 did. Took a 65 mile ride lastnight and it felt like a truck...
Are the stock shocks that crappy? Any suggestions as to what to change them too??
Thanks in advance....
Old 05-31-2013, 11:38 AM
snelldawg's Avatar
snelldawg snelldawg is offline
snelldawg is starting off with a positive reputation.
Shocks will help out. A lot of people upgrade to the Rancho 9000's or Bilstein 5100's. There are a lot of threads on the Super Duty and 6.7 Diesel forums (on FTE).
Also, the stock steering stabilizer (aka shimmy shock) seems to be inadequate. Upgrading that to a Bilstein 5100 is money well spent IMO. If you are getting feedback in the steering wheel when going over bumps it will settle that down.
Either shock I mentioned above will provide a firmer but consistent ride. The Rancho's are adjustable so you could dial in the settings you prefer for the best ride.
Old 05-31-2013, 11:59 AM
8iron 8iron is offline
8iron is starting off with a positive reputation.
I upgraded to Rancho 9000's and the improvement was considerable. Before switching out the OEM shocks I would not let my wife drive my truck on grid roads...any washboards made the truck almost uncontrollable! Too bad we have to spend good money just to make these trucks drivable.
Old 05-31-2013, 12:14 PM
smokewagun smokewagun is offline
smokewagun is gaining momentum as a positive member of FTE.
Researching this myself, Bilstein 5100s are not recommended for stock height trucks. They are better for lifted trucks. The Heavy Duty Bilstiens are recommended for stock rigs. The internals are the same so Bilstein says, but 5100s look nicer in chrome. I was told 5100s are a waste of money unless I am lifted.
Old 05-31-2013, 12:22 PM
bryyce62's Avatar
bryyce62 bryyce62 is offline
bryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud ofbryyce62 has much to be proud of
Quote:
Bilstein makes the 5100 series for stock height Superduties.
24-186018 front 0-2" lift
24-186025 rear 0-1" lift
24-196284 stabilizer
Bilstein is my choice for shocks.
Give shock warehouse a look-see.
gw
Old 05-31-2013, 01:36 PM
snelldawg's Avatar
Both the 5100's and HD's are for stock trucks. I wasn't able to find out the true difference, if any, between the two besides the finish. I had the HD's on my last truck and wanted to try something different. Both shocks are a great upgrade over stock. The 5100 does allow for a leveling kit up front since they are for up to 2 inch lift.
Old 05-31-2013, 05:59 PM
Mmaxed Mmaxed is offline
Mmaxed is gaining momentum as a positive member of FTE.
My opinion for what it is worth. If you mostly run empty or lightly loaded go with the Bils. The extra rebound damping is a big advantage. But if you carry heavy loads or a fiver with a heavy pin weight the 9000s are better as you can stiffen them up to match the load. I've had both on my V10 and the ranchos are there now for the trailer.
Old 06-01-2013, 08:16 AM
Dave HM Dave HM is offline
Dave HM is starting off with a positive reputation.
When I picked u[p my 2012 F250 I thought, "Man this thing rides like it has concrete tires."
Air pressure was 70.
I had the TPMS reprogrammed and let some of that air back out in the atmosphere. The difference was noticeable.
Old 06-01-2013, 08:06 PM
GSSF17's Avatar
GSSF17 GSSF17 is offline
GSSF17 is starting off with a positive reputation.
Mine rides like a pickup truck.
"felt like a truck"....... Sweet! Perfect.
Old 06-01-2013, 09:13 PM
Thanks for the info on the shocks.I will look into the blistiens seeing as the truck runs mostly empty.I know its a pick up and not a car, just wanted a little nicer ride...got spoiled having that F150 after my other F250
Old 06-02-2013, 04:54 AM
GSSF17's Avatar
Quote:
haha....I was only bustin' on ya
Ride and steering quality with additional 4" lift Jon Gleason 1999 to 2016 Super Duty 5 01-31-2017 10:58 AM
F250-F350 ride TreverAdamo 2017 Super Duty 7 10-19-2016 12:12 AM
Do leveling kits affect the ride??? ommegang 2009 - 2014 F150 24 03-07-2014 02:39 PM
2013 Lariat Rough Ride mmikemitchell 1999 to 2016 Super Duty 2 03-24-2013 10:09 PM
Stock Ride Height tbzep 1997 - 2003 F150 2 03-18-2013 08:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
