2008 ford F650 5.9 cummins injector knock - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 05-31-2013, 08:08 AM
l-m tech l-m tech is offline
l-m tech is gaining momentum as a positive member of FTE.
hello all, i have a freind that has a 08 f650 with the 5.9 cummins and allison trans in a roll back chassic.the truck has 40k on it and has what sounds like a injector knock.he had a company put a tuner in it and when he got it back it had a knock in it.this was the next day and only drive 2 blocks with it to has shop.he told the guy that that noise was unacceptible.they removed the tuner and the noise is still present.he took it to ford cause it still had warranty.ford said theres nothing wrong,its normal.he took it to a dodge shop and they said that the crank needed to be replaced.i have a hard time beleiving that the truck needs a crank.the vehicle is out of warranty now and the noise is the same as it was 10 months ago.anyone run into this before. thanks for the info.
Old 06-01-2013, 08:38 AM
no takers.anyone lead me to the forum that might help
Help! Dads in deep...Need advice! sean9049 6.0L Power Stroke Diesel 11 10-07-2015 03:24 AM
92 f250 7.3l worth buying?? joshua1514 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 18 11-28-2011 10:11 PM
5.4L ...the knocks just keep on coming. mjandros Modular V8 (4.6L, 5.4L) 7 08-26-2009 08:47 AM
Head Gaskets, EGR, Tuner.. What I learned from the Tech at the dealer today. 2000Mark 6.0L Power Stroke Diesel 86 01-03-2009 09:04 PM
Oil Pressure Problem.... I Need Help!!! WHITE F350 6.0L Power Stroke Diesel 23 01-15-2007 02:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
