Manifold to Exhaust Bolt Size - Ford Truck Enthusiasts Forums
Old 05-30-2013, 10:57 PM
Blue50F-1's Avatar
Blue50F-1 Blue50F-1 is offline
Blue50F-1 is gaining momentum as a positive member of FTE.
Question for the part number gurus...
I've posted this a couple other places...the more lines in the water the better your chance of a catch...BUT...
I'm looking for the size/tpi of the bolt that connects the exhaust pipe to the exhaust manifold on 70's SBF's. I've got a 302 with 78 and 75 exhaust manifolds replacing my old 69 manifolds that were cracked and broken, but the old bolt doesn't match up. Long story short, I need the bolt that connects the manifold to the exhaust pipe. I can't find one in my limited supply that fits.
Thanks!
Jim
Old 05-31-2013, 01:31 PM
baddad457 baddad457 is offline
baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.baddad457 has a very good reputation on FTE.
They're not bolts, they used studs here. They're 7/16" NC if I'm not mistaken. Dorman used to make these, proably still do.
Old 05-31-2013, 03:08 PM
Blue50F-1's Avatar
BD,
Thanks for the reply. On my old manifolds, the RIGHT had studs, the LEFT had bolts. On the new (salvage) manifolds they're just threaded holes on both sides. I picked up 7/16-14 bolts as that's what went in the old LEFT manifold and I figured the newer ones would take the same. The 7/16-14 bolts go in about two threads and stop. I tried a 3/8 bolt it just slides right in and out. So 7/16 is the right diameter. I think NC would = 14tpi, meaning I might just need to tap out my manifolds. But if they're 16 or 12tpi I could really make a mess of things!
Thanks again for the reply!
Jim
Old 06-01-2013, 07:34 PM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
As Baddad has said, the manifolds should be fitted with studs, not bolts. The thread is 7/16-14, i.e. standard coarse thread.
The fact that you found bolts used simply indicates that someone improperly reassembled the parts at some point.
The threads on the manifold are regular threads, but the studs have a special interference thread design to keep them from unscrewing. Double nut them to insert (poor quality replacement parts may not have this feature).
You can probably still get the studs from your local Ford dealer.
Use never-seize on the nuts.
Old 06-02-2013, 12:41 AM
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
I think my 390 has a somewhat similar setup. When changing a flang gasket I found a crack in the manifold. I salvaged a good replacement manifold. As far as the studs, i replaced with all new grade 8 studs and hardware. The parts store had quite a selection but all were either shorter or longer than what I needed. I got the longer studs and ground them down to the length I needed. I then applied a bit of High temp locktite and snugged them up.
This seemed to be the best way to replicate what Ford did on a dime. Hope this might help.
Old 06-03-2013, 09:14 AM
Blue50F-1's Avatar
Beans,
Thanks for the details. I got her sorted out over the weekend. I was worried I might crack the iron (or more likely cross threads) but I discovered that after running them in, the threads on the stud went from sharp points to dull rounds. I'm guessing this is the interference design you mention as the stud threads themselves were identical to the bolt threads.
Oh, and I'm a big fan of anti-seize!
Thanks Crazy for the info. For your sake, and the sake of anyone who comes after you, I hope you those studs never break or need to come out!
At any rate, this hurdle's been crossed. Thanks fellas.
Peace,
Jim
Another shorty header question thread silar 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 02-22-2015 07:05 AM
Exhaust Manifold to Pipe Connection montego69 1957 - 1960 F100 & Larger F-Series Trucks 8 07-27-2012 12:21 PM
exhaust manifold bolt size... emeraldcoupe 1973 - 1979 F-100 & Larger F-Series Trucks 0 09-04-2010 10:18 PM
1988 Ranger 2.9 Exhaust manifold to y pipe bolt size mihulka3 Ranger & B-Series 1 11-18-2009 02:39 PM
Air Injection Pipe Bolt Size skinsgamer Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 3 09-09-2008 08:02 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
