Brake Calipers Sticking - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-30-2013, 10:41 PM
bust7015 bust7015 is offline
bust7015 is starting off with a positive reputation.
Question Brake Calipers Sticking
I have a 2006 F250 SD, 6.0. I purchased it less than 2 years ago with 32000 miles. When I first got it, the RR caliper was hanging, A few days later the LR caliper started hanging. Still under the 60day warranty, the dealer replaced both calipers with new, not rebuilds. 7 months later, 40000 on the clock, the LR hung briefly a few times. A week or so later the RF caliper got hung and stayed there. Local shop replaced the flex lines at all four brakes, both front calipers New, not rebuilds, new pads and rotors, and flushed the system with new fluid. Here I am, 11 months later 47000 miles on the clock now and the LR caliper is hanging again. I am thinking something may be wrong with the ABS unit. This is getting expensive for a truck I don't drive that often, but I really enjoy it! Any ideas? Have there been any TSB's regarding this issue? Thanks for any input
Old 05-30-2013, 10:48 PM
JWC 3's Avatar
JWC 3 JWC 3 is offline
JWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputationJWC 3 has a superb reputation
Sounds like your guides may be corroding and sticking . Either your caliper pins or pad slides , or both . I see that a lot on the rears . And more on seldom used trucks .
Old 05-31-2013, 06:28 AM
Capt. Bob Capt. Bob is offline
Capt. Bob is starting off with a positive reputation.
I am having the same problem on my truck. I replaced the right front caliper back in August when it locked up. Every thing has been fine untill yesterday. The left front (driver side) did the same. I let it cool down and was able to get it home without a problem. If the caliper was bad would it be okay again after it cooled down. I don't use my truck much either. Maybe 3000 miles a year. Mine is a 2006 F-250 with a 5.4 engine and 98k on the clock.
Old 05-31-2013, 09:10 AM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
No, it will not be OK. They do not fix themselves.
Old 05-31-2013, 09:54 AM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
Those that live in salt country, lots of snow etc need to take the calipers off, clean the slides and take the slide pins out and grease them as well.
Old 06-01-2013, 07:47 AM
I replaced the caliper and hose on the drivers side. I could find no reason for the thing to stick. The pins were fine and had plenty of lub. on them. I guess the rears will start to go next.
Old 06-01-2013, 09:02 AM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
Quote:
Yes indeed, I do this once a year.
Old 06-01-2013, 09:07 AM
I don't drive the truck in the winter because I want it to last. BUT I will take the calipers off and do some maintenence. I really enjoy this vehicle! They don't call them super duty for nothin'!
Old 06-22-2013, 10:08 PM
jlrFordFan jlrFordFan is offline
jlrFordFan is starting off with a positive reputation.
Brakes dragging
My '08 F-250 has had a significant brake drag issue multiple times. It's not a caliper problem. Each of my fronts have dragged / hung up, and its happened on each of my rears twice each. The problem is the brake shoes(pads) corrode and stick in the guides. If you have this same problem you have to remove the guides and clean them up. I actually had to hammer the pads out of the guides to remove them. Even if you clean them up, and lubricate them you need to keep your attention on them because the brake heat combined with the pad/caliper dust will generally degrade the lube and cause the corrosion and sticking to return.
The number one cause is the truck sitting a lot. Mine sits ALOT, I only use it to pull the camper, and that's only about 15 times/year. After sitting the other primary cause is salt accelerated corrosion as cited by Senix above.
If mine keeps doing it I'm going to modify the pad guides with some slots to better hold grease, and start experimenting with high temp grease.
Old 06-22-2013, 10:27 PM
JWC 3's Avatar
Quote:
I have a customer that insists on high temp bearing grease on his pad backs and slides/pins . He is a retired Navy Sub tech . He must be on to something , he has about 550k on his Volvo car now .And no brake issues .Just a few wiring and A C issues .
Old 06-23-2013, 07:50 AM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
i never have issues with calipers sticking/freezing on vehicles that are always used.
but let them sit and it is a different story.
and i never have problems with the sliders, it is always the pistons freezing in the calipers.
metal or phenolic pistons, it don't matter. although the phenolic pistons do seem to last a little longer.
Old 06-23-2013, 08:02 AM
sledjunk's Avatar
sledjunk sledjunk is offline
sledjunk is starting off with a positive reputation.
I had issues like this with my old truck (Chev). I use my truck primarily for towing the sleds in the winter. I finally decides to drive the truck to work (100 KM round trip) at least once a week. The issues were greatly reduced.
Old 06-23-2013, 08:27 AM
I ended up replacing the caliper after cleaning the old one and putting new grease on the slides with no luck. No issues since... but I attended an event recently and ended up talking with a group of 11 super duty owners who drive their trucks daily or nearly as much all with the same recurrent problem. A NAPA store owner in attendance said that it is a problem that is inherent in the calipers. He stated it is caused primarily by poor quality control by rebuilders but said to check for bad bearings as a possible cause. Guess I'll carry a spare caliper with me on vacation!
Old 06-23-2013, 12:52 PM
Gage2502's Avatar
Gage2502 Gage2502 is offline
Gage2502 is gaining momentum as a positive member of FTE.Gage2502 is gaining momentum as a positive member of FTE.
Ya my driver side rear was sticking yesterday. I got it home and lifted the rear and it started to move freely, going to really check it this week.
If I need to replace the Caliper should I use OEM Motorcraft?
Is there a way to make sure that the pads are ok and rotor? It was sticking for about 5-10 miles then it became unstuck. The wheel was warmer than the other 3 than when it became unstuck it wasn't warm anymore.
Also I have just over 30k miles on my truck....I guess I should drive it more.
Thanks
Old 06-24-2013, 07:06 AM
The first time I replaced the calipers, I went to Ford and they used Reman units from Motorcraft. They lasted about 8 months. One stuck and a few days later the other side. Just sayin' Sad thing is I drive my old Honda Civic daily with 250K with the original calipers all around
Is there a fix for sticking rear brakes that works? mxhowes1 1999 to 2016 Super Duty 19 01-07-2016 12:38 PM
Brakes pulling to the left and running hot 02 F 350 7.3L Diesel nvrsadi 1999 to 2016 Super Duty 4 11-07-2014 04:05 AM
brake bleed issue after IWE replacement theman79 2004 - 2008 F150 0 08-29-2014 10:26 PM
R/R brake caliper issues greenwoodford Excursion - King of SUVs 17 02-15-2011 09:16 PM
Right Rear Brake Caliper bigk_54 Excursion - King of SUVs 9 01-14-2011 06:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
