1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
glove box springs
Old 06-02-2013, 03:29 PM
62ESQ's Avatar
62ESQ
62ESQ is offline
glove box springs
Has anyone tried changing the glove box springs? I bought a new set and noticed that one spring has one thicker end than the other spring ends. Is one meant to go on a particular side? Since I don't have an old one on one side, it's hard to tell which is supposed to go where.
Old 06-02-2013, 04:37 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C1TB-8106112-A Right & C1TB-8106113-A Left .. Glove Box Door Assist Springs.
Applications: 1961/66 F100/1100 / 1963/69 N/NT/T500/1100 / 1967/69 F800/1000.
Old 06-03-2013, 12:29 PM
62ESQ's Avatar
62ESQ
62ESQ is offline
Does your exploded view show which part number is the thicker tipped spring?
Old 06-06-2013, 11:24 AM
NumberDummy
No it doesn't. Pic below same as 1961/63.
Old 06-06-2013, 04:04 PM
62ESQ's Avatar
62ESQ
62ESQ is offline
Thanks for the pic! it is helpful. After crawling around under the dsah some more, it does look now like the spring with the thicker end is on the left side of the glove box when facing the dash. I'm going to try to remove and replace the springs tomorrow, so I'll report back how that went!
Old 06-07-2013, 06:41 PM
62ESQ's Avatar
62ESQ
62ESQ is offline
Mission accomplished! Got the springs on without removing the glove box or the heater. Not much room for my hands under the dash while up side down. The thicker tipped springs goes on the left side as you face the glove box and the thinner on the right. The trick was to put the spring on the bottom hinge first then attach it to the top. Glove box door closes nice and tight now.
UnknownCubicle
05-10-2020 05:08 PM
hoofmender55
05-14-2019 09:00 AM
mytoolman
02-28-2019 08:53 PM
rjf1785
01-14-2013 09:53 AM
1972RedNeck
05-07-2012 01:57 PM
Quick Reply: glove box springs
