Front end rattle F-150
I have a 97 F-150 4wd and when I drive over rough places on the road you can hear a rattling noise. It also causes my truck to thud loudly. But also as I just coast at about 10 mph with the window down you can hear that rattling noise. Almost sounds like a washer sliding on a shaft or something. You can definatly tell something is loose in the front end when i hit rough places. We've jacked it up and tried to move the wheel and the bearings and ball joints seem tight. Any ideas? Thank you gentlemen.
If that isn't it...then maybe start looking over shocks and heat shield on the exhaust.
I've got a similar issue with my '02..... Discovered what it was while changing the oil last weekend. My sway bar end link on the drivers side front had a bushing missing....so basically the bolt that holds the sway bar to the frame was rattling and would thud when I hit a bump. New bushings should be arriving today.
I had a noise problem a little like yours on my 2001 F150 & thought it might be the front end. Took it to a front end place, they diagnosed a rotted out radiator core support, with the radiator & AC condenser hanging by their hoses. I was one good bump away from my engine &/or auto tranny self-destructing. Surprisingly the thing that was the easiest to see was a lower-than-normal position of the radiator. The core rot was 98% obscured by valances & other parts installed in the front end of the engine compartment. My dealer missed the diagnosis a few months earlier when he replaced the gas tank straps under a recall.
This is an extremely common problem in NE Ohio.
This photo is of a junkyard F150, where I slashed the valance apart, but did not remove it from the bottom rail of the core support. The severe rust is not visible:
This is what the above bottom rail of the core support looked like from above after I removed many items from the front of the engine compartment
On that particular model, removing the bumper to core support valance would have caused the core bottom rail to fall out & hit the ground!
This is what my particular F150 looked like after I removed the things which obscured the damage:
There is a long thread on what I have been doing here: https://www.ford-trucks.com/forums/1...l#post13186822
with a photo of a junkyard F150 missing the lower rail of its core support. There is a photo of my truck after I replaced the support & before I put everything back on it.
Here's a photo of core damage in an earlier F150 model
and another view:
Same truck after missing material replaced with sheet metal, welded & painted:
