PHP hydra
Old 05-30-2013, 08:45 AM
cps's Avatar
cps
cps is offline
PHP hydra
Does anybody have any pictures of of the Hydra installed in their truck? As in, where you put the digital switch.
Old 05-30-2013, 09:35 AM
ScaldedDog's Avatar
ScaldedDog
ScaldedDog is online now
Mine's in this post.
Mark
Old 05-30-2013, 10:29 AM
cps's Avatar
cps
cps is offline
Mark
Thanks. Did you use velcro to mount it to your dash? Debating on a Hydra or an F6 tuner but i want to know my my mounting options before i buy. Both seem to be good tuners for our trucks and the service from both seem good also and i don`t want to hack up my dash or, at the very least, as few holes as possible.
Old 05-30-2013, 11:03 AM
ScaldedDog's Avatar
ScaldedDog
I cut a hole in my dask to accomodate the JMS switcher from DP. The Hydra switcher doesn't quite fit that mount, but a little work with a file made it fint. I suspect, but don't know, that you could make any of the DP mount options work.
I personally hate velcroed crap, but lots of folks don't mind it all, and it does open up mounting options.
Good luck with the tuner choice. Both DP and Gearhead (what I run on the Hydra) write great tunes, but neither are perfect. I much prefer DP's shift strategies for towing, but prefer Matt's engine calibrations. I actually switch between the F5 and Hydra depending on whether I'm towing, or not, and that's a real pain.
Mark
Old 05-30-2013, 11:08 AM
HKusp's Avatar
HKusp
HKusp is offline
DP has a switcher that fits in a gauge hole and they also have a mount that fits around a gauge (links below). I have an original plastic prototype of the one that fits around the gauge and have had it for almost 5 and a half years. The production ones are made of metal. It looks crooked in this photo, but at the time, I had it upside down. It sits straight now.
http://www.dp-tuner.com/ford-powerst...her-mount.html
http://www.dp-tuner.com/ford-powerst...lack-face.html
Old 05-30-2013, 11:40 AM
BWST's Avatar
BWST
BWST is offline
Got Data?
I'm a lefty, so mine is on the other side of the steering wheel from Mark's.
Old 05-30-2013, 01:42 PM
Km1210's Avatar
Km1210
Km1210 is offline
Not a Hydra chip, but close enough. It just sits there and doesn't move or rattle. I like it.
Old 05-30-2013, 02:19 PM
ScaldedDog's Avatar
ScaldedDog
Jeff, I think where we have ours is the handiest place on the dash. Easy to see, easy to reach, out of the way...
Mark
Old 05-30-2013, 03:12 PM
BWST's Avatar
BWST
BWST is offline
Got Data?
I agree with you, Mark.
x2 on the DP shift strategies. They work very well for towing. I like the engine calibrations as well, but only have the edge juice to compare to. What a difference! I am limiting the rig to 60e and 60t, because 80e and 80t maxes out my HPOP (AE says IPR duty cycle is 100% at times, and ICP is down to 1700psi)
Old 05-30-2013, 05:19 PM
Bonanza35's Avatar
Bonanza35
Bonanza35 is offline
Time for a T500 Jeff, I really like mine!
Old 05-30-2013, 06:12 PM
BWST's Avatar
BWST
BWST is offline
Got Data?
That is true - a T500 is in my future. I'm hoping to limp along until new sticks are needed. I'm happy with the power with what I currently haul and the mountain passes I travel. Shoot, I'd be happy to have clean coolant at this point.
Old 05-30-2013, 07:26 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Mark
I kind of agree!
My old F250 truck:
Originally Posted by Stewart_H
Here is where I have mine mounted.I don't have my switch box pushed all the way into the flush mount because I want to keep the option of pulling it and taking it with me so the truck won't start. Since it's such a tight fit, the way it sits in the mount is VERY secure.Stewart
Stewart
Old 05-30-2013, 07:50 PM
ScaldedDog's Avatar
ScaldedDog
Stewart, when I was figuring out my install, your pics helped me make the decision.
Mark
Old 05-30-2013, 08:57 PM
Stewart_H's Avatar
Stewart_H
Right on!
Stewart
Old 05-31-2013, 02:26 AM
hydro man 17's Avatar
hydro man 17
hydro man 17 is offline
Stewart, doesn't even an empty mounting hole raise an eyebrow when you go to get a smog check? Or do you have a user friendly station? I need to get my first check by the end of the month but the switch is just velcroed on. The bigger issue is my AFE Bladerunner intake manifold. From what I understand it has been tested and reviewed by CARB but no results last I checked as to weather it will be street legal.
Quick Reply: PHP hydra
