heavy smoke
heavy smoke
mornin all, my 96 7.3 has been sitting for a year, running itall the time but just around yard. got low on fuel so i ran it to fill it up.heavy smoke out exaust, whitish lightblue. drove around block couple times again lastnight, same thing. think from sitting or something wrong? dont smoke at idle or reved up 147k miles thanx all
If it's been sitting a lot, and only been moved a little around a little, you could have some oil in places that needs to be burned. O-rings could be an issue. But I'd change the oil and filters (fuel too) and take it for a drive and get it good and warm and see if that doesn't get it cleared up.
My 95 sat up for about a year and is doing something similar.
It is puffing a bit of whitish smoke out of the tailpipe under acceleration. It seems to puff more if I turn the chip up to higher power levels. I drove it around about 60 miles today, stop and start, and highway speeds. I took it over 3000 rpms on a couple shifts and I even cruised at 2300rpm in 5th for a bit. Seems to still be smoking under heavy acceleration.
I've been told faulty injectors can cause that, and I have 240,000 miles, so it wouldn't surprise me.
They probably are, everything I repair appears to be original, lol. It still has the complete exhaust along with a host of other easily replaceable items. I think it may still have a dual mass flywheel too.
I have looked at injectors before and avoided pulling the trigger because of pricing. I guess I should search a few threads to see what the cheapest way of doing it is. Hopefully my cores can cover most of the purchase price.
In the meantime I am gonna run this old fuel out and see what a fresh tank, with some two stroke in it, does.
custom_nirvana
13
07-22-2009 10:45 AM
