Compression Ratio question.
Old 05-29-2013, 09:52 PM
pw87's Avatar
pw87
pw87 is offline
I recently finished putting a 460 in my 92 F150. I used an engine from a 91 FI and the heads, intake, and carb from an 84. I am very impressed with the performance (possibly cause I am used to the 302) Durring the build i noticed that the FI pistons are shallower than the carb ones. I figured that the difference in the heads probably make these two engines close to the same compression ratio when stock. I was wondering if anyone knows what the compression ratio is with the FI pistons and the carb chambers?
Another thing, Is there a difference in the camshafts in those two engines?
Rembrant
34
05-18-2018 07:47 AM
jerm111
07-03-2010 09:32 PM
evam350
09-30-2007 07:44 PM
fastford456
03-06-2003 12:31 PM
BlueOvalRage
02-02-2003 11:14 PM
Quick Reply: Compression Ratio question.
