Compression Ratio question. - Ford Truck Enthusiasts Forums
Old 05-29-2013, 10:52 PM
pw87 pw87 is offline
pw87 is starting off with a positive reputation.
I recently finished putting a 460 in my 92 F150. I used an engine from a 91 FI and the heads, intake, and carb from an 84. I am very impressed with the performance (possibly cause I am used to the 302) Durring the build i noticed that the FI pistons are shallower than the carb ones. I figured that the difference in the heads probably make these two engines close to the same compression ratio when stock. I was wondering if anyone knows what the compression ratio is with the FI pistons and the carb chambers?
Another thing, Is there a difference in the camshafts in those two engines?
1980 300 6 cyl CR raven3 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 01-23-2014 08:33 PM
351w engine build suggestions BuiltFordTough302 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 2 12-19-2013 03:43 PM
What did Ford change internally when they went to e.f.i.? x_man586 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-19-2013 09:02 AM
460 versus 7.5 Need help! Two Lane Black Top Performance & General Engine Building 7 08-04-2013 11:45 PM
Need help! 460 versus 7.5 Different? Two Lane Black Top Computer Chips & Tuners 2 08-04-2013 05:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
