aluminum intake bolts
Old 06-08-2003, 10:03 PM
79_ford_400_guy's Avatar
79_ford_400_guy
79_ford_400_guy is offline
u dont need diff. bolts for aluminum intakes do you? such as on heads?
Old 06-08-2003, 11:07 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
I use stainless steel on everything that goes into aluminum and also use anti-seize. Steel into aluminum is cheap but a No No. I also use Stainless on all bolts exposed to coolant like the thermostat housing.
Old 06-09-2003, 09:31 AM
beartracks's Avatar
beartracks
beartracks is offline
I'd stay away from chrome. They may gall. Anti sieze is always a good idea.
Old 06-09-2003, 09:42 AM
laptopgeek's Avatar
laptopgeek
laptopgeek is offline
79_ford_400_guy -
I bought pretty ones from Summitracing - they are steel, but have real purty heads on them; just makes it look better. Like the wire looms I have on the 460 - not really a "have-to", but sure impresses the gurlz at the local soda shop when I pop the hood......
Old 06-09-2003, 12:03 PM
7220driver's Avatar
7220driver
7220driver is offline
Also, it's a good idea to use plain flat washers under the bolts to prevent chewing up the manifold surface as you tighten them. Use the same material as your bolts.
