Well I finished the work and Im going tu upload several pics of it, Im going to start with the parts I used or fabbed then with the parts mocked up and then the final set up. There are some pics of the infamous plug and the new one and the tools I had to use to pull them with the WP in the vise. Also I made the KAWA (Rog) Shroud mod:
First the tools I used to unbolt the infamous WP plug and the old and new WP:
What is the WP plug size. I need to get mine out and don't want to remove the entire WP. It looks like a standard 3/8" pipe plug. Can anyone tell me what size the socket to remove it? I can get one but I need to know what the Size is.
I dont remember, but Im going to see IF I have it and tell you, OK ?
That would be great. I need to know if it is metric... or sae. I put a 12 point 7/16 socket on the square head. It holds but a little sloppy. Might slip if a lot of pressure is applied so I will need to get a square socket that will fit.
I twisted a swivel in half so I need some idea of how someone else removed that plug.
Well, I tried to remove the plug with the WP installed and was impossible. , and even in the vise was difficult and with a big pipe wrench as you can see in the pics of the first post. So good luck.
Wix makes Napa filters, so they are the same. I can't remember for sure, but I think the 4070 is just the filter, the 4071 has 1 unit of SCA, the 4072 has 2 units. I don't remember the bran of filter that is release on need. It is something like Penray.
Yes you are correct. But what I want to know is how the units effect my system and do I need the units? The also have a 4071T and I have no idea of what the T is,.
