1962 F250 292 Y-Block Water Pump Pulley - Ford Truck Enthusiasts Forums
Old 05-29-2013, 04:37 PM
jawroper jawroper is offline
jawroper is starting off with a positive reputation.
I am having a devil of time finding a water pump pulley for my 1962 F250 292 Y-Block. Is there an recommended interchangable water pump pulley? I could find one in my Hollander Interchange books.
Thanks
Old 05-29-2013, 09:24 PM
schoo's Avatar
schoo schoo is offline
schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.schoo has a great reputation on FTE.
Quote:
Thanks
What pulley do you have now?
Also ck my thread on alternator this forum
Old 05-29-2013, 10:09 PM
It's the original pulley, but the v-groove has a spot that is bent. I couldn't find an ID on it.
It's a 4 bolt, center hub is 3/4, the offset appears to be 2 17/32 according to my caliper, and the OD is 6 1/4.
Old 05-29-2013, 10:18 PM
schoo's Avatar
Where in as are you in az bill w might be of help I know who has one but may be pm bill w
Old 05-29-2013, 11:07 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
I probably have an extra one if you can't find one closer.
Old 05-30-2013, 08:56 AM
SevensGarage's Avatar
SevensGarage SevensGarage is offline
SevensGarage is starting off with a positive reputation.
I just pulled the factory one groove pulley from a 292 yesterday. PM me if you need it. Or you could run up to your local hot rod shop and purchase a GM type single or double groove pulley for a short pump and it'll work. Reason i took this one off was to install a 2 groove GM since i added power steering and needed that extra groove to run the PS pump.
Old 05-30-2013, 09:05 AM
Old 05-30-2013, 12:58 PM
camperspecial65 camperspecial65 is offline
camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.camperspecial65 has a good reputation on FTE.
Jaw, There were 2 pulleys used on F series Y blocks in 1962...one has a depth of 2 45/64"
The other has a depth of 3"...the 2nd one has a p/n C1TZ8509F...Green Sales in Ohio has 2 of them puppies..800-543-4959
Good Luck, cs65
Old 05-31-2013, 02:42 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
C0TE-8509-F .. Waterpump Pulley-Single Sheave / 6 21/64" O.D. / 2 45/64" depth / Obsolete
1957/60 F100/700 272/292 / 1961/62 F100/700 292.
MILLER OBSOLETE PARTS in Binghamton NY has TWO = 607-722-5371.
Quote:
Originally Posted by camperspecial65
There were 2 pulleys used on F Series Y blocks in 1962.
OP has a 1962 F250, C1TE-8509-F is a 6 19/64" O.D. double sheave pulley w/a 3" depth and is listed for 1961/62 F500/700 292 ONLY!
Old 05-31-2013, 12:05 PM
jbwpunk jbwpunk is offline
jbwpunk is starting off with a positive reputation.
I can come grab it this weekend and see if I can find a gm one over at Grumpy's that will match
292 Water pump and pulley BelgianF100 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 02-02-2016 10:21 PM
292 Motor mounting question jaggermk 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 11-13-2014 08:22 AM
water pump repair (y-block) Stephen67 1948 - 1956 F1, F100 & Larger F-Series Trucks 10 06-12-2014 03:54 PM
Y-Block 292 Water Pump Connection? jawroper Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 5 06-21-2013 04:07 AM
Need 1962 F260 Info rmpatterson 1961 - 1966 F-100 & Larger F-Series Trucks 2 08-15-2003 10:17 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
