Bump side bronco - Page 2 - Ford Truck Enthusiasts Forums
Bump side bronco
Old 05-29-2013, 04:29 PM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
I was thinking he started with a 78 / 79 Bronco and grafted the panels, changed the doors and front fenders. The top is real close to what my 79 looks like. From what little i can see of the front frame it looks like my 79 with the double shocks. Don't know just guessing , i wish he showed more detail and told a little more about it.
Old 05-29-2013, 04:31 PM
67-F100's Avatar
67-F100 67-F100 is offline
67-F100 is starting off with a positive reputation.
thats awesome! i want that!
Old 05-29-2013, 10:57 PM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
Looks like we have acouple different opinions on what exactly is going on with this bronco I may have to give this guy a call and see if he will mind going into detail of what exactly he did but man is it one interesting build or what?
Old 05-30-2013, 01:36 AM
Tinstar36 Tinstar36 is offline
Tinstar36 is starting off with a positive reputation.
I like it wish I had the money for another project
Old 05-30-2013, 03:37 AM
RichS2659 RichS2659 is offline
RichS2659 is starting off with a positive reputation.
Jim, there is precedence for this swap as I have seen a bumpside cab and shortened bed welded together just like the integral bed 61-63 F-100's mounted on a 78-79 Bronco chassis running around Nampa. I believe that this is a bump cab and bed with a 78-79 Bronco roof and fiberglass cap mounted. The Bronco roof must be just a little bit wider than the bump roof as you can see a parting line where the two meet. People have kind of done the same thing to Bronco II's to make them have a removable top like the early Broncos.
Jim, I'm curious where the shot of your Bronco was taken.
Old 05-30-2013, 07:48 AM
__________________________________________________ __________________________________________________ ___________
The picture was taken in my back yard towards the north in south west Idaho about 35 miles west of the state capital , Boise Idaho. 5 miles farther to the west is the Snake River which is the state line to Oregon. You can't see it in the picture due to some overcast but the "Sawtooth" mountains are to the north and east of us and the " Owyhee " mountains to the south and west. . If not for the overcast you could see some high snow covered mountain peaks when it was taken.We live in what is referred to as the "snake River Plains" area.
I'm thinking you may be right about how it was put together. If you look close and compare my bronco roof to it there is some difference in them.
The tail gate looks like a pickup tailgate not a bronco one.
Old 06-06-2013, 10:42 AM
Ford 67 Ford's Avatar
Ford 67 Ford Ford 67 Ford is offline
Ford 67 Ford is starting off with a positive reputation.
Thumbs up
That's just too cool. Proportions seem good from pics. Someone on the forum needs to get this.
If all the welds and fab work are done correctly it's worth what he's askin and he'd probably come down a bit. Later.
Old 06-06-2013, 11:58 AM
elgemcdlf's Avatar
elgemcdlf elgemcdlf is offline
elgemcdlf is gaining momentum as a positive member of FTE.
If it is the truck I think it is there is not too much of the '78/'79 Bronco left body wise. There was a build somewhere on the net of this type of truck. He took a pickup & cut everything he needed from the truck to make it a Bump Bronco. He put the roof panel from the pickup, door jambs, extensive work in the rear to make all that work back there. If I remember correctly the front portion of the floor is bump grafted into the Bronco rear floor panel. The build might even be here at FTE if someone did a search for it.
Old 06-06-2013, 01:19 PM
BradyCouchman's Avatar
BradyCouchman BradyCouchman is offline
BradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud ofBradyCouchman has much to be proud of
Quote:
I texted a bit with the owner, very nice guy. He cut mid roof and forward off a dent bronco and grafted in a bump cab (doors and all) with the back cut off. then cut the rear fenders out and grafted on bump fenders.
Said this was his first try at something like this, i think he did a GREAT job. and said that he didnt do a write up on it anywhere on the net.
Old 06-06-2013, 01:31 PM
damarble damarble is offline
damarble is gaining momentum as a positive member of FTE.damarble is gaining momentum as a positive member of FTE.
Pretty cool! Imagine if he'd done a crew cab.
Quote:
I thought that looked familiar. I spent my teenage years in the Caldwell/Parma area.
Old 06-06-2013, 02:29 PM
MIKES 68 F100's Avatar
MIKES 68 F100 MIKES 68 F100 is offline
MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.MIKES 68 F100 has a good reputation on FTE.
If i was closer this would already have a home !
Old 06-06-2013, 05:31 PM
elgemcdlf's Avatar
There is 1 on the net also. Imagine that 2 trucks like this.
  #28
Old 06-06-2013, 05:47 PM
I live on a small acreage 2 miles north of Parma , been in the general area most of my life and I'm an old codger.
  #29
Old 06-06-2013, 11:35 PM
As they say, small world. I lived on Roswell Rd and worked at the U of I in Parma.
  #30
Old 06-06-2013, 11:51 PM
Brady thanks for sharing what you found out that sure clears it up alot about this mystery machine. Looks like he did a good job from everything that he's done to it any idea on man hours involved? If it were closer I believe I'd have this by now.
full size Bronco rear shell on a 67-72 bump lilorbie 1967 - 1972 F-100 & Larger F-Series Trucks 5 12-29-2016 05:30 PM
Franken Bronco/craigslist find of the day buckin69bronco 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-05-2014 05:24 PM
Why is a bronco II called a bronco II? mdr617 Bronco II 20 03-17-2011 12:01 PM
buying a Bronco II Zack93 Bronco II 4 08-05-2010 10:43 AM
Bronco Cooling (Full Size)? AlM 1978 - 1996 Big Bronco 4 11-04-2001 10:45 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
