fuel rich
05-28-2013, 09:50 PM
fuel rich
89 E250 351W EFI
has too rich gas smell from exhuast so i check fuel pressure it showed 40 PSI it good but i have no idea why gas too rich ?
05-28-2013, 11:02 PM
05-28-2013, 11:57 PM
Quote:
Originally Posted by
tabijan
The O2 sensor might be faulty. Here's some reading on testing the O2 sensor -
o2-sensor-testing .
Sixto
93 E150 Chateau 5.8 185K miles
Thanks for info... but why dont computer warning light on "check engine" if oxygen sender is failed?
05-29-2013, 07:13 AM
on
Because the Oxygen Sensor is still working - but just not right.
If you disconnect the Sensor, the "Check-Engine"-Light goes on.
05-29-2013, 01:23 PM
Off topic - later vehicles (OBD-II?) have a downstream O2 sensor to validate the signal of the primary O2 sensor upstream of the cat.
Sixto
05-30-2013, 08:05 PM
Cobra-Kai
let you know i did disconnect oxygen sensor and "check-engine" not come on..
what next?
05-31-2013, 07:42 AM
on
That's odd.
I disconnected mine and the light went on...
Does it always smell like gasoline or only when the engine is cold?
05-31-2013, 08:24 AM
A dirty air filter will do this, too.
05-31-2013, 01:48 PM
Stupid question but does the check engine light come on before you hit the starter?
Sixto
05-31-2013, 06:04 PM
on
does the engine run rough?. my '99 had 1 bad plug and for some reason did not trigger the check engine light. that was the gas smell and soon after the check engine light did come on
06-01-2013, 08:14 PM
tabijan
Sixto
yes it does check engine light come on when i hit starter after started light go away.
06-01-2013, 08:15 PM
i just finished install new oxygen sensor and Map sensor now rich fuel go away!! feel little more power now
EllieMae94
60
12-09-2017 05:28 PM
lupin398
03-19-2011 09:03 PM
Dayne
1983 - 2012 Ranger & B-Series
04-08-2004 11:27 PM
cheesedog1
Aerostar
08-27-2003 09:55 AM
