I pulled the motor on our F100 with a 360 to repair a slight rod knock. Much to my surprise, I found a rod bearing in the bottom of the pan. Motor has 88000 original miles and has not been apart (as far as I have been told). Any ideas how it got there? It is a Ford stamped bearing?
Is this possible, for the life of me I cannot see how it could "escape" the cap. Bearing is dirty but has little wear. I will pull the caps off next but all had about the same up and down movement.
Was it a complete bearing half?? Missing a rod half would make quite a racket. Montana is prolly correct. I have found a partial cam bearing in the pan before. Wore down to the point it worked its way out. I was confused myself, til i figured it out.
Complete half, motor is pretty quiet other than a slight knock on decel.
