75 Highboy Resto-Mod Build
#332
I was mainly just waiting until I did the motor since this kit requires the 3G alternator swap and so I can set it up for HEI ignition. I only wanted to do it once.
#333
#334
http://www.carbdford.com/tech/HEI/hei.htm
#335
That's not too bad then. You can wire ANY ignition system into ANY vehicle, a Duraspark distributor makes this pretty easy and it's one of the best designs ever made, MSD modeled their distributor after it. The HEI Ignition Control Module is a decent little unit, there are multiple to choose from concerning Rev Limits how the ignition acts, it's also quite compact. I do suggest that you find/make something to protect the module from the elements as it will no longer be housed inside the distributor, maybe even mount it inside the cab, somewhere Dry and Cool would be ideal.
#336
#337
I used the ez wire in my truck. The quality was great but I think for the extra money I'd go with a complete plug and play harness. I never got my gauges to work. Admittedly I'm not the best at wiring but I'm not a complete idiot either!
#338
#340
#341
Shot the firewall with some low gloss engine enamel today. Look nice and clean now. I'll spray the frame too once I do some welding on it.
If anybody has any pics of factory V8 engine mounts on a 77-79 F-250 chassis it would be appreciated, because I'm working with this crap where they just hacked the 460 in.
#343
Did you have them install new Cam Bearings?
What all did you have them do? Chamfering holes, chasing threads, bore size, line bore the mains, deck the block, resize the rod ends, assemble the bottom end, blueprint an oil pump, balance the rotating assembly? Did you have them do your heads also?
#344
Did you have them install new Cam Bearings? What all did you have them do? Chamfering holes, chasing threads, bore size, line bore the mains, deck the block, resize the rod ends, assemble the bottom end, blueprint an oil pump, balance the rotating assembly? Did you have them do your heads also?
#345
