2006 F250 6.0 Diesel getting Fuel in water, almost burned truck up HELP!!! - Ford Truck Enthusiasts Forums
Old 05-28-2013, 06:29 PM
frogjaw's Avatar
frogjaw frogjaw is offline
frogjaw is starting off with a positive reputation.
Exclamation 2006 F250 6.0 Diesel getting Fuel in water, almost burned truck up HELP!!!
I have a 2006 F250 that I recently did a head job on, the other day it caught on fire. It burned wires hood everything. I somehow got fuel in the water and it leaked on the exhaust which ignited it. I asked a few people what might cause this and the answer I got was a leaking injector tube. Is that the reason, and if it is how can I tell which one is leaking without pulling all of them One more question.... Do I have to lift the cab again or should I just get full coverage insurance lol......
Old 05-28-2013, 06:30 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
Moving post to 6.0L PSD engine forum.
Old 05-28-2013, 06:32 PM
frogjaw's Avatar
Sorry...... I was just in a hurry......
Old 05-28-2013, 06:38 PM
mustang_309's Avatar
mustang_309 mustang_309 is offline
mustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to beholdmustang_309 is a splendid one to behold
Cracked injector cups is how you end up with fuel in the coolant. Pull the injectors and pressurize the coolant system and watch the injector cups for coolant. The fix is a new head.
Old 05-28-2013, 06:39 PM
Rusty Axlerod's Avatar
Rusty Axlerod Rusty Axlerod is offline
Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.Rusty Axlerod has a spectacular reputation.
Don't sound good. Fuel in coolant is at least injector cup in cylinder head and more likely it's cracked head (s). Injector cups can be replaced, there is a tool to do the job, but it's seldom a lasting repair according to our Ford Techs here.
Old 05-28-2013, 07:33 PM
69cj's Avatar
69cj 69cj is offline
69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future69cj has a brilliant future
Agree with Rusty on this one. Mustang was also correct but didn't go far enough.
Old 05-28-2013, 07:43 PM
frogjaw's Avatar
Thanks for the advice. I think I'm going to do the cup replacement..... What kind of tool does that require??
Old 05-28-2013, 07:44 PM
cheezit's Avatar
cheezit cheezit is offline
cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.cheezit has a spectacular reputation.
you have one trashed head and a crispy truck
Old 05-28-2013, 07:49 PM
frogjaw's Avatar
I just replaced the head gaskets last month..... Took them down and had them resurfaced and tested for cracks. I replaced the radiator and the fan clutch and had no more overheating issues. I'm crossing my fingers on this one...... I do have a crispy truck.
Old 05-28-2013, 08:03 PM
big inch big inch is offline
big inch has a good reputation on FTE.big inch has a good reputation on FTE.big inch has a good reputation on FTE.
One of the heads is most likely cracked. You can usually tell which cylinder is the culprit by looking at the injectors once they are removed. There will be one that has a different appearance. The last one I did was cracked under the cup, and the cup had to be removed to see the crack.
Old 05-28-2013, 09:13 PM
frogjaw's Avatar
What kind of tool do you need to remove the cup?
Old 05-28-2013, 09:24 PM
I haven't seen one. Just saw a few posts about it. I imagine it bolts to the head and grips the cup somehow to pull it and press the new one in. Search function might pull up a post or two. Might call local dealership, believe it is a Ford tool.
Old 05-28-2013, 09:30 PM
frogjaw's Avatar
I will be starting the job tomorrow afternoon, I will keep everyone posted, and put a pic of this tool up as soon as I get it. Thanks everyone for all the help......
Old 05-28-2013, 09:37 PM
Good luck with it. Hope I haven't led you astray, the point of the posts I've read is that replacing the cup didn't fix the truck, all of 'em had cracked heads.
Hey Guys, smell me! Post #3,000
Old 05-28-2013, 10:52 PM
The removal tool is a large tap with a threaded hole in the end to attach a slide hammer to.
Help..... Fuel leak. Tdoyle03 1994.5 - 1997 7.3L Power Stroke Diesel 7 04-01-2015 03:05 PM
Oil Leak Mustanghowie 1999 to 2016 Super Duty 0 11-09-2013 01:16 PM
1990 f250 diesel leaking tigerblood 1987 - 1996 F150 & Larger F-Series Trucks 5 10-04-2013 10:09 AM
2011 fuel system issues 2dumbnotto 6.7L Power Stroke Diesel 311 01-29-2012 09:06 PM
2000 f350 7.3 with 350,000 is leaking diesel burning coal 1999 to 2016 Super Duty 7 10-30-2010 11:19 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
