1996 cc refurbish/psd swap
#61
#65
#66
Thanks, I should be able to round a few used ones up somewhere. I aught a get to my local yard too, haven't had the time. Now i regret being impatient and breaking some of them lol
#68
Some more progress, slow, but its getting there.
made the puller to get the cab mounts off the brackets
cleaned up the rad support a bit to fix it up, and got the fender ready for new paint.
I sand blasted the brackets and hangers, this little gravity fed mac speed blaster is handy as hell. worked great for little stuff. I also got the springs apart. wire wheeled them, those are going to get paint too.
I am killing my poor car pretending its a truck haha
I also saw this valence with spots for lights, never seen one before. thought it looked good, well at least on a rollback
well the next step is por 15 on the frame and brackets and everything. then maybe I can finally start putting it back together
does anyone know where i can get those little plastic bushing things that go between the leafs, mine were all worn out.
#71
I had one on my truck and killed it my father-n-law still has one on his truck I will try to get some pics.
#73
#74
I just wanted to ask you how good your Speed Blaster gun is?. It’s easy to use?. Do you have to cover yourself when using it? The lightweight and ergo-balance of the gun make me think that is the one I want to have/use for a small to medium size job. Its easy to get the grid?
#75
that gun has me intrigued, too. looks like its about $50 on amazon and sounds like lots of people just run regular play sand through. that, plus a face shield and a non-rainy day and paint-prepping parts or frame sections with hard-to-grind places would be much easier.
i'm going to be cleaning, rust-converting and coating the frame of my 'new' f350 section by section as I do work to it, so this would be perfect. I should get my extra reservoir hooked up to my pancake compressor first, though...
