Nebraska Chapter Join Chapter, Leader: 97nukeford
Garage heat
Old 12-28-2013, 02:50 PM
sd1972's Avatar
sd1972
sd1972 is offline
Garage heat
Just a question do any of you guys heat your garage/workshop? If so what do you use? I am getting for waiting for warm days to work on my truck or other projects.
Old 12-28-2013, 03:42 PM
flyboy2610's Avatar
flyboy2610
flyboy2610 is offline
Garage? What garage?
Old 12-30-2013, 11:11 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
Hey David. All I have right now is this 240V little box heater from Northern tool. Works okay when it's about 25 degree's or more, otherwise it's too small.
NewAir Electric Garage Heater — 19,107 BTU, 240 Volts, Model# G56 | Electric Garage Industrial Heaters| Northern Tool + Equipment
I would have done a propane, but I don't have the venting necessary for it.
Old 12-30-2013, 11:24 AM
jseim44's Avatar
jseim44
jseim44 is offline
When I lived in town my shop had electric baseboard heaters in it. Not the most efficient, but it was warm. I've also got a Knipco style propane heater that works well. Not as stinky as the kerosene ones but still need some ventilation. I've thought a wood stove would be alright, but it's a bit harder to control the heat.
Dad has the infared propane ones. They are OK but it's about 1000 degrees under them, then the farther away you get the colder it is.
The floor heat in out shop at work is REALLY nice!
ANY heat is better than NO heat
-Jake
Old 12-31-2013, 09:21 AM
67nukeford's Avatar
67nukeford
I plan on using a heated floor, when I put up my shop.
Old 01-13-2014, 11:23 PM
eviiltim72's Avatar
eviiltim72
eviiltim72 is offline
I am just using a small propane forced air heater. It's about 45,000 btu and heats my 2 car garage to about 80 when its below freezing outside in less than an hour.
Inside Man
34
12-29-2018 12:33 AM
fellro86
Garage & Workshop
18
05-08-2012 09:13 PM
rtcalabrojr
17
01-26-2009 09:00 PM
bigwin56f100
Ohio Chapter
11-12-2008 08:27 PM
Prometheus
1997-2006 Expedition & Navigator
01-27-2006 12:28 AM
Quick Reply: Garage heat
