1979 f800 tranny swap - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 05-27-2013, 11:06 PM
jbonco jbonco is offline
jbonco is starting off with a positive reputation.
my 79 f800 has a 5 speed spicer tranny with three speed auxillary (brownie)
and single speed rear end. just cant seem to get the hang of shifting the brownie. considering doing a swap. My truck is a dump 34,000 GVW with 450 motor. Any tranny suggestions.
thanks all
Old 05-28-2013, 01:01 AM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
That's going to cost you.
"450 motor"? Is this a Ford gas engine? Possibly a 477 or 534?
Look for used transmissions here:
Fuller Transmissions on VanderHaags.com
Can you change the trans yourself, removing the main and aux. boxes?
If not, I can't imagine you could have a shop remove your existing setup and replace it in less than 15-20 hours. Add the clutch and driveline work, and I would be surprised if you could do this for less than $5000.
What trouble are you having shifting your existing set up?
Old 05-28-2013, 08:38 AM
yes I would do it myself. Problem I,m having is not with the transmission it is the operator. I dont usually have any difficulty upshifting the brownie the problem is mostly when I upshift the main and downshift the brownie. cant seem to get it without grinding gears. I don't normally even think of using the low unless I am stopped with a load. so normally it is just going from the high to direct drive that gives me the problem. I have nobody available to actually drive it and show me so I am just trying to teach myself and it is not going too great.
Old 05-28-2013, 10:24 AM
I see from your posts you've had this thing a while. And several other posts etc to get it running and starting.
Your experience reminds me of a Clark crash box in an old GMC my dad had. It was a real grinder.
Serving suggestion: Go here:
Washington Chapter - Ford Truck Enthusiasts Forums
and go to your prior posts. You have some replies fro rummer s. c. in Seattle, and there is a map there with member's locations. MAYBE you could meet up with someone, have them drive it and compare it with other similar units. Maybe it's just the way it is, maybe it doesn't shift quite right.
Anyway, imo, a different trans for this seems like a lot of money and effort. Of course, I'm not the one trying to row through those gears.
Good luck with it.
Old 05-30-2013, 08:12 PM
TheRedPheonix's Avatar
TheRedPheonix TheRedPheonix is offline
TheRedPheonix is starting off with a positive reputation.
If you can't find a person to show you how to shift it, maybe you could find an old trucker on a web forum that could explain the proper sequence to shift smoothly. That way somebody is at least identifying what you are doing/not doing correctly. Maybe even somebody here on this forum. But a tranny swap just sounds like an awful lot of effort and money unless the one you have is trash.
Old 05-30-2013, 09:20 PM
gandrimp gandrimp is offline
gandrimp is gaining momentum as a positive member of FTE.
Youtube has a vid of an older guy shifting a brownie, he made it look easy. I have only been around one, and it was years ago,,, I can still hear the grinding.
Old 05-30-2013, 09:39 PM
raystankewitz's Avatar
raystankewitz raystankewitz is offline
raystankewitz is gaining momentum as a positive member of FTE.
Hmm . . .
A two-sticker can be a hand-full if you've never been schooled in floating the gears.
I learned from an old-timer that the clutch was only used for stopping and starting. All shifts, according to him, were done by 'floating' the gears and matching engine speed/transmission speed/road speed. I quickly understood you need to 'hear' the right rpm for the gear change.
Upshifting - Main up/brownie down was done main box first.
Downshifting - Brownie up/main down was done brownie first.
The reason for that was the first shift was easy, since the engine speed would be low. The second shift of the appropriate box was done by getting the stick into N, revving up to the right rpm, then easing it in. Don't shove it into gear, try to feel the gears engaging while you gently put it into gear.
And, if you're driving an old B-series Mack, it is okay to reach through the steering wheel to shift the aux box.
Anyway, just my 0.02 USD worth.
Ray
Old 05-31-2013, 12:35 AM
A New Brownie thread . . . acheda Clutch, Transmission, Differential, Axle & Transfer Case 359 06-07-2016 08:56 AM
Brownie Box 3 speed 5531a ford390gashog All Other Items for Sale 1 05-08-2016 03:09 AM
tranny troubles Brownies old blue 94 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 01-03-2015 12:33 AM
76 F250 brownie box? 76er 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-23-2014 09:37 AM
3 Speed Brownie Transmission MJD Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 11 04-25-2012 01:26 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
