Remote Turbo 460 w/ Video
Old 09-18-2011, 05:21 PM
Lead Head's Avatar
Lead Head
Lead Head is offline
We finally finished the remote turbo setup on my buddy's '96 F-250 CC SB 460 E4OD.
It's a TP-38(I believe?) Garrett Turbo from a 7.3 PSD Van (so it has the larger turbine housing). It's mounted just behind the cab, the exhaust from the turbo goes right into the y-pipe for the stacks (Stacks on a gasser ). Exhaust is 3" all the way from the collector to the turbo, no cat, no muffler, smog pump + related ancillaries removed. All emissions equipment has been disabled in the computer.
Boost piping is 2" from the turbo and runs along the passenger side frame rail, where it goes up into the engine bay. It goes from a 2" to 3" adapter, where it goes to into the intercooler. The cooled air charge than goes through a 90mm Lightning MAF to an adapter for the dual throttle bodies.
Wastegate is some cheap ebay thing, seems to work. BOV is an OEM Bosch unit from some porsche, was only about $15 and works great.
36 lb/hr injectors (might be 38, can't quite remember) being sequentially controlled through a 95 F-150 California E4OD 5.0 computer. We're using a Moates QuarterHorse and the BinaryEditor software to tune it along with an AEM Wide-Band O2 gauge + sensor.
Here's the video I'm sure you're all waiting for. It was running horribly rich in this video, probably 7:1-8:1 air-fuel ratio. He's only averaging 5 mpg right now. He went about 3/4 Throttle @ ~6PSI in the video. I'm sure he'll gain quite a bit of power once we get the tune dialed in, and he is actually able to open it up fully. There will be a build thread with pictures later.
Turbocharged 460 F-250 Drive - YouTube
Old 09-18-2011, 08:10 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
We need pictures of the setup along with more video! I'd like to see how you mounted the turbo, piping, and where you're intaking air to keep it dry and free of debris. Also, could you get any video of the truck from outside (I'd like to hear the exhaust).
How's the turbo working out? Does it spool correctly? How's the lag? Does it run out of steam with the higher RPMs of the 460 over the 7.3? I've got plans to do a turbo 460 of my own (probably with a Megasquirt ECU), but am unable to decide if a "remote" mount turbo behind the cab is the way to go over smaller twin turbos in a front mount setup.
Is the motor stock or have you made internal upgrades?
I'm looking forward to seeing more of this truck.
Old 09-18-2011, 08:52 PM
Lead Head's Avatar
Lead Head
Don't worry, pictures will come soon.
We haven't really tested lag, etc..because we need to get the tune straightened out first. It's injecting about twice as much fuel as it should be. But so far it doesn't seem to have any trouble getting the turbo going.
The larger housing on the van turbo is better suited to the 460 than the standard 7.3 truck turbo. The 460forum guys seem to agree that the 7.3 turbo is pretty well matched for a mild 460 turbo build. But we have the rev-limiter set at ~4300 RPM for now anyways. There's a local speedshop with a chassis and engine dyno, so we'll see where its running out of steam.
Internals are stock, so we're keeping boost to around 7 PSI for now. After my friend gets back from basic, he's going to pull the engine and drop some forged pistons and rods in it. Probably going to be looking at around 10-12 PSI with that.
Old 09-18-2011, 09:42 PM
DIYiT's Avatar
DIYiT
DIYiT is offline
How much of a difference in the truck and van 7.3 turbo is there?
Do you plan on keeping the stock heads or will you be going to aluminum to help with detonation? What CR are you going to aim for? How much power do you think the turbo will support?
(I think I'm going to have a crazy amount of questions for you as this goes on )
Old 09-18-2011, 09:59 PM
Lead Head's Avatar
Lead Head
The truck turbo has a 1.0 AR housing, the van has a 1.15. I'm not sure exactly what that means in terms of performance, but in general, the more exhaust flow your engine makes, the bigger your housing should be. A larger exhaust housing will take more to spool however.
He'll probably keep the stock heads to keep costs down. The 460 already has fairly low compression, but he'd probably go 8:1 at the lowest. Part of the turbo goal was to try and keep stock-like drivability without really hurting fuel economy.
There's still a lot left for us to research when he finally does decide to take it to the next level.
Old 09-19-2011, 04:36 AM
mgroshong's Avatar
mgroshong
mgroshong is offline
Good work guys, i will be watching this thread.
Old 09-19-2011, 12:30 PM
Lead Head's Avatar
Lead Head
Updated with some pictures here:
https://www.ford-trucks.com/forums/1...l#post10826497
Will be next week before I can get the rest of the pictures, sorry!
Old 06-02-2013, 08:19 PM
biggreen95's Avatar
biggreen95
biggreen95 is offline
Is the '96 MAP or MAF? If MAP how did u go about the conversion to MAF.?
Old 06-02-2013, 09:58 PM
Lead Head's Avatar
Lead Head
It was MAP, we converted it to MAF with a '95 F-150 California system
Old 06-03-2013, 10:17 AM
biggreen95's Avatar
biggreen95
How did you go about the conversion? Wiring harness, computer, and MAF sensor?
Old 06-03-2013, 12:15 PM
Lead Head's Avatar
Lead Head
Yup, that's the basics of it.
Old 06-05-2013, 03:42 PM
biggreen95's Avatar
biggreen95
Do you know of any other vehicles I could pull the the brain wiring harness and Maf sensor out of to convert my '95 f250 with the 460 to MAF?
Old 06-06-2013, 10:03 AM
Lead Head's Avatar
Lead Head
If you have a 5 speed you can use an A9L mustang computer. This is not just a drop in swap, you will need to tune the computer, or have someone tune it.
Old 06-06-2013, 07:07 PM
biggreen95's Avatar
biggreen95
Plan on going the quarter horse route. The mustang brain will only work with a 5spd?
Old 06-06-2013, 08:56 PM
Lead Head's Avatar
Lead Head
Yes the Mustang A9L will only work with a 5 speed or C6 (3 speed) automatic truck.
If you have an E4OD, you'll need a computer from a 94/95 F-150 5.0 California E4OD truck.
Bonehead101
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
03-01-2016 08:08 PM
Gormanj91
16
01-09-2013 04:05 AM
Dustin460
09-11-2009 01:29 PM
lazyscholar
01-05-2008 12:31 PM
BlackHillsCowboy
02-11-2005 04:06 PM
Quick Reply: Remote Turbo 460 w/ Video
