1989 F-450 10 lug wheels - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 05-27-2013, 09:31 PM
Barry Eck Barry Eck is offline
Barry Eck is starting off with a positive reputation.
We have two 1989 F-450 & 1992 Super Duty with the 16" Wheels 10 lugs.
Can we get 19.5" wheels with that bolt pattern? What year did these trucks change over to the metric bolt pattern?
Have been looking it seems like they are available on the newer style 450 & 550. Would a larger 22.5" wheel also available?
Just wanted to check out the options before purchasing 6 new tires.
With the larger tires & wheel we would improve the fuel economy ect..
We appreciate your feedback.
Ty,
Old 05-30-2013, 02:34 PM
truckdog62563's Avatar
truckdog62563 truckdog62563 is offline
truckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud oftruckdog62563 has much to be proud of
I know that Rickson Wheel used to list 19.5s for your 10 lug x 7.25" hub piloted F-450 mounting. But I don't see them listed now. Pretty sure this pattern was used through 1997, same as the F-250/350s used the 8 x 6.25" through 1997 before going metric in '98. I also checked my OEM wheel listings and see that 16" was all that was offered by Accuride and K-H. You might Google Rickson (I'm using the phone and can't do a link) and contact them to see what they can offer. You could also go to a custom builder like American Wheel Specialist in Pasco, WA, or Wheels Now in the Milwaukee area. Stu
Old 05-30-2013, 03:12 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Rickson shows a 19" upgrade for Ford F53 chassis motorhomes:
Rickson Wheel Manufacturing
Looks like it might work, but you'll need to check.
Old 05-30-2013, 04:02 PM
There it is, I knew I'd seen it but didn't look deep enough. Thanks. Now to argue with their recommended tire sizing. A 225/70R19.5" tire will be about 32" outside diameter, while an 8R19.5" will be 33.5" to 34". The taller tire will yield better road speed and economy. Stu
Old 05-30-2013, 06:14 PM
1989 F450 10 lug wheels upgrade to largest wheels
Will need to contact Erickson Wheels and see if the sell them with the older style bolt pattern do not need to purchase the Aluminum Wheel the steel ones will work fine.
Ty, for your reply and tip.
Barry
Old 06-02-2013, 11:30 PM
1956f450 1956f450 is offline
1956f450 is starting off with a positive reputation.
An economical 19.5, 10 lug wheel can be sourced from a P30 or a Chevy 3500 HD. The bolt patern is the same, but you will have to put them in a lathe and enlarge the center whole to the Superduty spec which is 5.460". I went with the taller 8Rx19.5 tires and they work and look so much better on my 1956 F 450.
Old 06-02-2013, 11:39 PM
Thanks for the great tip,
What years on the Chevy 3500 HD? Where might be a source to purchase some of these Chevy rimes
Also what is a P30?
Would like to see a picture of your 1956 F450 with the 19.5
Thank you again!
Old 06-03-2013, 05:46 PM
A P30 is a General Motors heavy duty van type truck such as a bread truck type or small school bus. They are very common in small school buses. All of the 3500 HD's with 10 lug wheels should work also. I have some good photos and as you can tell, I'm new to posting. If someone will tell me how, I will post some pics of my wheels and my truck if you are interested. With 5.13 gears, it was well worth the change to the taller tires.
Old 06-03-2013, 09:46 PM
Not sure myself and have been on here for a couple of years. We have two duel wheel axles w/ the 513 gears 7.3L 5 speed ZF Transmission.
If you would send them to me @ barryeck@verizon.net
We appreciate your knowledge and help.
Thank you again
LT265/75R16 tires on Dually a2dudley 1999 to 2016 Super Duty 4 08-29-2011 07:52 PM
F450 Wheels change out: 19.5 or 22.5 kingfish 6.7L Power Stroke Diesel 1 09-27-2010 04:34 PM
87 f 150 4x4 Is my wheel lug pattern 5 lug 5.5 bolt pattern? l67cooled 1987 - 1996 F150 & Larger F-Series Trucks 1 11-12-2009 09:51 AM
F-450 lug patterns????? steelers06steelers 1999 to 2016 Super Duty 3 05-11-2008 10:45 AM
F-450 Wheel Adapters bobsok 1999 to 2016 Super Duty 0 10-16-2006 05:14 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
