No Oiling Right Bank of Rockers
Messed around with it again today, and while it is oiling now, it's a lot less than the driver side. Ran it with both valve covers off, and there's a lot more flow on one side. Might have to tear the rocker assembly all the way down and make sure it doesn't have any debris in it. If not, I worry that the cam bearing has turned enough to start blocking the passage.
So if it's not the rocker shaft being plugged, how do I go about drilling out that bearing?
I just figure if the bearing started to move, I wouldn't mind fixing it now before it goes into the pickup, instead of chancing it moving a bit more and blocking off. There's a sheen of oil on everything, but none at all coming out of the tube (and it's not blocked). It's just not flowing as much as I'm comfortable with, especially in the higher RPM range.
Myself I like using them...
Jim
Thanks Dennis, thats the same I was told by a few others. I like using them too but now I'm having second thoughts about it. When I changed my rockers to the higher ratio ones ( 57-58 ) I added the drip shields but that requires running the adjuster down to compensate for the shaft sitting higher, that changes the ratio lower, so I may have defeated the purpose
Jim
Jim
However, on an average street engine, you won't gain much and it would be mostly for bragging rights.
You have decreased the ratio but there is a lot more to it. By adding the drip shields, you have also changed the geometry, probably for the better and that is a good thing. What you really need is a set of custom length pushrods, and if you really want to go all out, get the geometry just right.
stormchaser70
07-11-2009 03:50 PM
1pump
18
09-11-2007 11:55 PM
