No Oiling Right Bank of Rockers - Page 2 - Ford Truck Enthusiasts Forums
Old 06-01-2013, 06:08 PM
ihateminimumwage's Avatar
ihateminimumwage ihateminimumwage is offline
ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.ihateminimumwage has a very good reputation on FTE.
Messed around with it again today, and while it is oiling now, it's a lot less than the driver side. Ran it with both valve covers off, and there's a lot more flow on one side. Might have to tear the rocker assembly all the way down and make sure it doesn't have any debris in it. If not, I worry that the cam bearing has turned enough to start blocking the passage.
So if it's not the rocker shaft being plugged, how do I go about drilling out that bearing?
Old 06-01-2013, 06:44 PM
charliemccraney charliemccraney is offline
charliemccraney is gaining momentum as a positive member of FTE.charliemccraney is gaining momentum as a positive member of FTE.
I wouldn't be too concerned about it, as long as it is getting oil.
Old 06-01-2013, 07:02 PM
I just figure if the bearing started to move, I wouldn't mind fixing it now before it goes into the pickup, instead of chancing it moving a bit more and blocking off. There's a sheen of oil on everything, but none at all coming out of the tube (and it's not blocked). It's just not flowing as much as I'm comfortable with, especially in the higher RPM range.
Old 06-03-2013, 07:43 AM
WALFORD'S 56 WALFORD'S 56 is offline
WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.WALFORD'S 56 has a great reputation on FTE.
I have several oiling units that use the coppper tubing and help out with oiling issues. Bill
Old 07-16-2013, 08:24 PM
The Horvaths The Horvaths is offline
The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.The Horvaths has a good reputation on FTE.
Question
If it gets to one head but not the other I doubt that it's the bearing having turned. More likely a restriction at the dreaded dog leg or head/rocker shaft interface.
In other words, if the cam bearing turned, shouldn't both heads see a shortage of oil flow?
Inquiring minds want to know.
Old 07-17-2013, 03:59 AM
I built a fitting and ran low-temp grease down the head to the dog leg and got a pop still haven't ran the engine up to temp to get it oiling properly, so I think I found the problem.
Old 07-17-2013, 10:13 AM
Y-Blockhead's Avatar
Y-Blockhead Y-Blockhead is offline
Y-Blockhead is starting off with a positive reputation.
Quote:
Originally Posted by hiball3985 View Post
I apologize for changing the subject but the pictures of the rockers reminded me of something. Why do some Y's have the oil drip/deflector shields that bolt under the rocker shafts and some don't?
Jim, didn't see you ?? answered so I pipe up. Ford stopped installing them in ~'57. Price cuts?
Myself I like using them...
Old 07-17-2013, 01:34 PM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
Thanks Dennis, thats the same I was told by a few others. I like using them too but now I'm having second thoughts about it. When I changed my rockers to the higher ratio ones ( 57-58 ) I added the drip shields but that requires running the adjuster down to compensate for the shaft sitting higher, that changes the ratio lower, so I may have defeated the purpose
Jim
Old 07-17-2013, 03:42 PM
Jim
You have decreased the ratio but there is a lot more to it. By adding the drip shields, you have also changed the geometry, probably for the better and that is a good thing. What you really need is a set of custom length pushrods, and if you really want to go all out, get the geometry just right.
However, on an average street engine, you won't gain much and it would be mostly for bragging rights.
Old 07-17-2013, 04:19 PM
hiball3985's Avatar
The last thing I need is bragging rights, it's just a stock 292 street engine. I only used them because they were in better shape then what was on there and I like the adjuster better then the screw and lock nut ones that it had. You are right about a slight change in geometry too. I guess after the drip shields were discontinued they built thousands of engines with the geometry changed.
Wiring in Ignition Switch in 1966 F100 ihateminimumwage Electrical Systems/Wiring 7 09-26-2016 12:58 PM
Stripped Threads in Carb Inlet Peice ihateminimumwage 1961 - 1966 F-100 & Larger F-Series Trucks 13 07-28-2013 04:20 AM
Carb Fuel Inlet Replacement? ihateminimumwage Ford Inline Six, 200, 250, 4.9L / 300 1 07-19-2013 09:32 AM
Look What Followed Me Home Today... ihateminimumwage 1961 - 1966 F-100 & Larger F-Series Trucks 20 07-01-2013 01:41 PM
She ain't pretty, but she's mine - And I have some questions... ihateminimumwage 1961 - 1966 F-100 & Larger F-Series Trucks 32 06-19-2009 09:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
