2003 6.0 no crank
Old 05-25-2013, 01:11 PM
shamrock442's Avatar
shamrock442
shamrock442 is offline
2003 6.0 no crank
my 2003 6.0 just died driving down the road. coasted into parking lot tried to restart nothing no crank or clicking at all. all the dash lights came on glow plug light etc but no crank. I have replaced the hpop icp, ipr. truck ran fine after that but then this issue started. also tried to pull codes with my sct tuner and my scan gauge 2 both power up when plugged into obd2 port but just say connecting and never connect. I pulled both the ficim and the pcm and they were put into another 2003 and the truck ran fine...... checked for chaffed wires till the cows come home and cant find anything. batteries are both good. any help would be greatly appreciated! thanks Mike
Old 05-25-2013, 01:14 PM
amdriven2liv's Avatar
amdriven2liv
amdriven2liv is offline
I'm hitting easy street
Are wires getting warm at the starter?
Try pulling the serpentine belt and see if it cranks.
Old 05-25-2013, 01:25 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
Try unplugging the clutch fan and see if it will crank.
Old 05-25-2013, 03:10 PM
shamrock442
Unplugged still no crank jumped starter with yellow wire on passenger side got it cranked
Old 05-26-2013, 02:38 PM
shamrock442
But still no crank from ignition also replaced ignition switch......checked the pins to the obd2 have battery voltage there but both my SCT tuner and my scan gauge 2 can't connect.
Old 05-26-2013, 02:41 PM
shamrock442
Also wires are fine at starter no heat there. Also checked all the areas in previous threads for chaffing. Didn't find any???
Old 05-26-2013, 02:48 PM
mustang_309
Have you tried starting it in neutral. Have you checked all of the fuses including the ones in the engine compartment on the drivers side?
Old 05-26-2013, 03:34 PM
Rusty Axlerod's Avatar
Rusty Axlerod
Rusty Axlerod is offline
From m-chan68 in a post on a similar problem:
The PCM is not supplying ground to the ground side of the starter relay for whatever reason. Start unplugging three-wire sensors under the hood, one at a time, until communication is restored to the PCM for the engine to resume cranking over again. I would start with the fan clutch wiring connector.
__________________
http://www.yorkdaleford.com/service.html[/url]
Ford Diesel/Senior/Master Tech
Sound to me like he's saying possible vRef short. Also check fuse 22 he mentions.
https://www.ford-trucks.com/forums/1...-no-crank.html
Old 05-26-2013, 05:21 PM
shamrock442
Checked all three wire connectors I could find still no go
Old 05-26-2013, 05:23 PM
shamrock442
Also no start in neutral
Old 05-26-2013, 06:44 PM
BLADE35's Avatar
BLADE35
BLADE35 is online now
you need a DVM to check the PCM Plud and the OBDII Port
Old 05-26-2013, 07:18 PM
shamrock442
Checked power to obd2 it has battery voltage at required pins. Also the PCM and ficim work fine I another 03 6.0 but when back in my truck worked great for a few minutes then no crank also truck says 4 low and it's electronic and I can't shift it out of 4 low either
Old 05-26-2013, 07:22 PM
Rusty Axlerod
https://www.ford-trucks.com/forums/a...7&d=1340424187
Here's the pin-out for the PCM. Check power to it.
Old 05-27-2013, 10:04 AM
shamrock442
Old 05-27-2013, 11:30 AM
shamrock442
Hey rusty if I am standing on drivers side looking towards passenger side from front bumper which plug is which on the PCM
Quick Reply: 2003 6.0 no crank
