1978 - 1996 Big Bronco
Bronco sitting for a year
Old 05-25-2013, 12:50 PM
SJW's Avatar
SJW
SJW is offline
Anything to be careful of other than fluids, before cranking it up?
Old 05-26-2013, 01:38 PM
Encho's Avatar
Encho
Encho is offline
The Southernmost Mod
Check all the hoses and replace the serpentine belt. Don't forget to check the differentials and add one of those treatment products for the gas since it's been in there for so long. The tires will probably need replacement too since they were sitting on the same spot for so long. So, appart from fluids, rubber is the other thing to keep an eye on, of course a fresh battery or if yours is still good have it properly charged before reusing it, you don't want it to overburden the alternator if the charge is too low.
Old 05-26-2013, 06:49 PM
MadMatt65's Avatar
MadMatt65
MadMatt65 is offline
Like Encho said, anything rubber should be checked and or replaced. The 1993 Bronco I acquired had been sitting probably 2+ years. My leather interior was destroyed by the Florida sun and non-tinted windows. My fuel pump looked like a science project gone wrong! I had to do 2 fuel injector cleanings. I've changed all the fluids in everything. As in your case like mine, the more you dig.....the more you're gonna find. Take your time and pick your battles!! Good luck!
Old 05-26-2013, 08:52 PM
Encho's Avatar
Encho
Encho is offline
Originally Posted by MadMatt65
... Take your time and pick your battles!!
That should be the oficial motto when working on these trucks, good one.
Old 05-26-2013, 09:02 PM
JWC 3's Avatar
JWC 3
JWC 3 is online now
I would add a wiring / electric inspection , as well as fuel lines . Reason , possible rodent damage . I see that issue often . I just happen to have an 87 Porsche in the shop that has been sitting in a garage for 15 years ! A nightmare ! But , the guy is willing to pay to get it running !
Old 05-29-2013, 08:44 AM
1_ton_bronco's Avatar
1_ton_bronco
1_ton_bronco is offline
All fluids and rubber.. Gaskets on motor/ trans.. And diff
Old 05-29-2013, 09:00 AM
Encho's Avatar
Encho
Encho is offline
Also, check all the greaseable spots, including the bearings in the front axle (the rear is axle bearings are better protected from the weather).
MasterRoop
Bronco II
09-22-2011 04:02 AM
JW1971
03-15-2011 12:58 AM
Aussie_F_trucker
12-27-2010 03:59 AM
WhëëlMå1
05-31-2008 11:09 AM
br0nc0
06-10-2007 03:45 PM
Quick Reply: Bronco sitting for a year
